regulated return
Old Feb 11, 2010 | 11:59 PM
kupaa's Avatar
kupaa
regulated return
Well just placed an order with Diesel site for a regulated return should get here next week.How hard is it to install?
Old Feb 12, 2010 | 08:38 AM
DieselCamper01's Avatar
DieselCamper01
I don't know the answer to your question Chris. Just wanted to say congrats on the purchase.
Old Feb 12, 2010 | 08:49 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
I'll make you a deal......send me a ticket and I will install it for you.
Old Feb 12, 2010 | 09:09 AM
PaysonPSD's Avatar
PaysonPSD
Me too!!!! And my ticket would be slightly cheaper.
Old Feb 12, 2010 | 10:00 AM
jeff7825's Avatar
jeff7825
I would take the turbo off to install it, although most directions I have read do the install with the turbo still on. I would not even think about doing one with the turbo still on. It's not too bad once you get everything off, just takes time to take things off to get to what you need to get to.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Feb 12, 2010 | 10:41 AM
PaysonPSD's Avatar
PaysonPSD
Chris,
Joking aside for now.
I haven't installed the DieselSite RR but my experience with the CCK was that the most difficult part was getting the stubborn driver side fuel rail plug to break loose. I had to resort to visegrips for that. An open end wrench kept slipping and was rounding off the square head. I actually had to use channel locks to be able to close the visegrips tight enough so they would not slip. I also removed the plenum bolt next to it for more room to get the visegrips on really good. Once it broke loose I could remove it with my fingers. The one at the front of the passenger side surprised me, it broke loose with just a small open end wrench. Hopefully they both come out easy for you.
After you get it all installed turn on the key and cycle the fuel pump and check for leaks before the initial start.
Old Feb 14, 2010 | 04:59 PM
kupaa's Avatar
kupaa
you guys are all to kind....
Old Feb 14, 2010 | 07:39 PM
big poppa's Avatar
big poppa
I actually had a harder time with the passenger side fuel plug, drivers side came right out. Spray those plugs a day before with WD-40 or PB blaster to help with the extraction.
Old Feb 14, 2010 | 07:50 PM
Izzy351's Avatar
Izzy351
I used a socket with a universal for the passenger side plug -- I had the unfortunate luck to round off the bolt that holds the damn belt tensioner on, so I had to remove the plug and install the adapter with it in place. Not too pleasant.
Old Feb 14, 2010 | 08:09 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i second the take the turbo out! i have the cpr+ RR and i love it! if youre thinking about it get the fuel bowl delete kit now and save yourself a second turbo removal. youre gonna love it! its by far the best money other than the BTS i have spent on my truck! should come from the factory with one installed.....
its not a hard install just make sure you take your time and get all the joints for the fuel lines in there and pressure test it before you put the turbo back on as well......
Old Feb 14, 2010 | 09:09 PM
MiamiPSD's Avatar
MiamiPSD
No need to take the turbo out. Be patient and follow directions. DieselSite RR is a very simple install with great documentation. All parts are numbered or lettered. Bob is always a phone call away.
Old Feb 15, 2010 | 07:52 AM
indyF-350psd
you could spend 20 minutes taking the turbo out or you can spend alot longer than that trying to get at the fuel rail plugs and taking out the old fuel lines. jmo........
HD Rider
Dec 20, 2012 10:49 PM
jrmII
Aug 15, 2012 09:02 AM
23larry24
Jan 9, 2012 05:47 PM
23larry24
Jul 18, 2011 06:09 PM
bcfordguy
Jan 22, 2008 04:53 PM
