Building DIY Regulated Return
Old Dec 17, 2012 | 10:31 PM
HD Rider's Avatar
HD Rider
I'm building a DIY Regulated Return and I'm looking for suggestions on which regulator to use.
Old Dec 17, 2012 | 10:35 PM
snakedoc's Avatar
snakedoc
i used clays frx. i know it is not a true RR but it worked great. along with SS braded fuel hose with AN fittings.
Old Dec 17, 2012 | 10:47 PM
HD Rider's Avatar
HD Rider
I'm doing a complete RR with bowl delet. I know there are kits but I sometimes like doing it all myself.
Old Dec 17, 2012 | 10:49 PM
mueckster's Avatar
mueckster
I have the Aeromotive 13109 with the #6 ORB ports. I used #6 steel pushlock and AN fittings with a nylon braided hose (synthetic inner liner) and Otiker clamps. I then covered them with wire loom to prevent chafing. I have a compression type adaptor fitting on the fuel tank suction tube that converts to AN. Almost all of my connections are AN and easily removed in case a hose needed repair or replacement. I did reuse the stock return line and hoses from the engine lower left steel line back to the tank.
Old Dec 18, 2012 | 08:22 AM
honeydew's Avatar
honeydew
The kit I have uses a Fuelab regulator, I think it's the 515 series. That or Aeromotive would be a good choice.
Old Dec 18, 2012 | 08:53 AM
trekbasso's Avatar
trekbasso
I like the idea of diy, but would spend as much if not more than Clay's Frx, by the time I did lines and all. Not wanting to ditch the fuel bowl ? so how well does Clay's do compared to a more elaborate regulated system?
Old Dec 18, 2012 | 09:22 AM
mueckster's Avatar
mueckster
Prior to going to my current system, I had the stock bowl and lines with a DIY "FRx" and modified Diesel Innovations billet FPR housing to plumb in the Aeromotive regulator. I noticed my biggest inmprovement in hp and tq when I went with the bowl delete and larger lines. The reason I went with the adjustable setup was that my Walbro fuel pump flowed more volume than the stock type FPR could handle and caused a higher fuel pressure than desired. My system is 3/8" all the way to the heads and back to the return at the front of the engine.
Old Dec 18, 2012 | 09:33 AM
trekbasso's Avatar
trekbasso
Thanks Roland, that makes sense with more fuel needed for your set up.
Old Dec 18, 2012 | 10:55 AM
AMG-SM's Avatar
AMG-SM
Here is one:
https://www.ford-trucks.com/forums/9...wl-delete.html
If you Gogle for diy regulated return, you'll get a few good hits to other forums as well.
Old Dec 20, 2012 | 10:49 PM
HD Rider's Avatar
HD Rider
Thanks Roland. That's the information I was looking for. Does that regulator have a port for fuel pressure gauge?
LooneyBin77
Jan 20, 2018 01:02 AM
carl2591
23
Jul 23, 2016 01:39 PM
GeorgePBurdell
1983 - 2012 Ranger & B-Series
Jul 10, 2015 11:28 AM
87f-150stepside
Jan 17, 2013 11:07 AM
v8xploder
1966 - 1977 Early Broncos
Apr 26, 2009 08:25 PM
