regulated return
Old Jan 22, 2008 | 04:14 PM
bcfordguy's Avatar
bcfordguy
regulated return
What are the benifits of a regulated fuel return? Will this help with anything on the six liter.
Old Jan 22, 2008 | 04:53 PM
4x4Mark's Avatar
4x4Mark
It will help to ensure consistent and equal fuel pressure to all injectors. This will both improve the longevity of your injectors and provide additional fuel should performance upgrades require it.
The stock system has a pressure bleed valve set at 60 psi as it leaves the secondary fuel filter. Downstream pressure is anything less than this and in some situations the injectors at the back of the heads may see considerably less. This also allows for variance between left and right banks.
As the Regulate Return measures/sets pressure after the injectors, you know they are all seeing the same values. Most of the systems also increase the volume entering the heads by increasing the size of the lines coming in, and removing the banjo bolts.
Mark
HD Rider
Dec 20, 2012 10:49 PM
jrmII
Aug 15, 2012 09:02 AM
23larry24
Jan 9, 2012 05:47 PM
23larry24
Jul 18, 2011 06:09 PM
kupaa
Feb 15, 2010 07:52 AM
