Hard Fault Code
Old Mar 25, 2009 | 09:25 PM
4x492150's Avatar
4x492150
Hard Fault Code
Anyone no what this is?
checked my check engine light and this is the code
Old Mar 26, 2009 | 12:08 AM
DasCheckers's Avatar
DasCheckers
So was it code 98?
Give us some numbers to work with here man!
Old Mar 26, 2009 | 09:10 AM
4x492150's Avatar
4x492150
oops
yea it was code 98
Old Mar 26, 2009 | 07:44 PM
DasCheckers
Did it pull other codes?
Old Mar 27, 2009 | 12:46 PM
4x492150's Avatar
4x492150
yea it also had code 53- tp censor voltage too high
Old Mar 27, 2009 | 07:17 PM
DasCheckers
So you have,
53 - TP circuit above maximum voltage.
and
98 - Hard fault present.
Hard fault means the sensor is currently out of range.
A memory code means it was out of range at one time.
The code 53 indicates the TP sensor is exceeding the maximum expected voltage.
If this code is received during the KOEO test, disconnect the harness connector from the TP sensor.
If the code 63 is generated, replace the TP sensor.
If the code 53 returns, repair the short to voltage in the TP sensor wire.
Check back bro!
Old Mar 28, 2009 | 01:15 PM
4x492150's Avatar
4x492150
alright ill give it a try
thanks
Old Mar 28, 2009 | 05:37 PM
DasCheckers
Check back with what you find man!
Old May 6, 2009 | 08:39 AM
4x492150's Avatar
4x492150
the wires coming off the tp sensor were touching. i just rplaced it and works fine. thanks
REPORANGER
1983 - 2012 Ranger & B-Series
Sep 19, 2019 08:28 AM
kbf1961
Oct 17, 2015 10:05 PM
Scratcher
Jun 21, 2010 03:29 PM
ford150man
Nite, Nascar & Other Limited Edition Ford Trucks
Mar 16, 2007 01:37 PM
4x4fordtrkn
Aug 31, 2004 09:33 AM
