Ignition Bezel
Old Feb 9, 2010 | 08:00 PM
jdv19's Avatar
jdv19
Ignition Bezel
Replaced my ignition switch in my 1977.5 F250 4x4. I bought the switch and cylinder at Napa then ordered the bezel from Dennis Carpenter because Napa couldnt get it. Well the bezel doesnt fit!! Has anyone else run into this problem before? Is there another place I can get a bezel that fits the switch from Napa. Thanks
Joe
Old Feb 9, 2010 | 08:42 PM
montana_highboy's Avatar
montana_highboy
That's kind of odd, does the DC bezel fit the old switch?
Old Feb 10, 2010 | 08:29 AM
jdv19's Avatar
jdv19
I don't know. The PO replaced the old one before I bought the truck and instead of putting in a OEM replacement switch the idiot put in some universal switch from auto zone. I can get the bezel started but it turns only about a 1/4 turn then gets wicked tight. I'm afraid to force it because of stripping it and then I won't be able to get anything on.
Old Feb 10, 2010 | 08:10 PM
jdv19's Avatar
jdv19
I called NPD and had them take a 76 switch and try to screw a bezel on and they said it would only turn 2 or 3 turns then stop. Is this the way its suppose to fit? Any ideas on what you guys have done with your trucks would be awesome.. my switch is just hangin there and I have a $20 bezel from DC that dont seem to fit.
Joe
Old Feb 10, 2010 | 08:14 PM
montana_highboy
I've never tried a DC bezel, i have a Napa switch that works with my original bezel, do you still have the original bezel?
Old Feb 12, 2010 | 08:03 AM
jdv19's Avatar
jdv19
I never owned the original bezel cause the stupid PO didn't save it when he changed things. Anyway I got in touch with Bronco Graveyard and had them take the bezel they sell, which DC makes and distributes to them and try and screw it onto a 78-79 switch. Well it worked. The guy that I was dealing with from BGY, Pat said it screws all the way down. I ordered the switch and it sould be here within a couple of days. I'll let you know how it works. Thanks for the reponse Montana!
Joe
Old Feb 18, 2010 | 08:12 AM
jdv19's Avatar
jdv19
Got the 78-79 switch and pluged it in. Screwed the bezel on but it doesn't tighten to the dash!! More and more problems with something that should be freakin easy! The entire part now just sits in the dash loose? Is there another part i'm misssing that retains the switch to the dash? Thanks
Joe
Old Feb 18, 2010 | 09:41 AM
460/5's Avatar
460/5
Zombie Survivalist
wow man. i dont know what to tell ya. put a new switch in my 76 first thing, cause the keys were lost. the new ignition switch went in exactly the way the old one came out...
Old Feb 18, 2010 | 10:56 AM
Poison Oil Racing's Avatar
Poison Oil Racing
Joe
That sucks. When I replaced mine it just went straight in.
Maybe put an o-ring around the bezel to see if that would tighten it up?
Old Feb 18, 2010 | 12:30 PM
montana_highboy
Without actually being there it's really hard to say what's going on, this should be 30 seconds and done, did you try screwing the bezel onto the switch before you installed it to see how far it screws on? maybe go pick up a few bezels at the junk yard and try them?
Old Feb 18, 2010 | 10:13 PM
73 fourxfour's Avatar
73 fourxfour
You are missing a part, the ignition mounting bracket. Probably only going to find it in the junk yard. The bracket has two bolts that mount to the bottom of the dash. The ignition sits in this mount and the bezel cinches it to the dash. The bezel only has to turn a few times.
Old Feb 19, 2010 | 08:04 AM
Ronzi's Avatar
Ronzi
I have the part you need. Pm me your info and I will send it to you.
Old Feb 19, 2010 | 08:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I just replaced the ignition switch in my 1977.5 F250 4WD
Got the 78-79 switch and plugged it in. Screwed the bezel on but it doesn't tighten to the dash!! More and more problems with something that should be freakin easy! The entire part now just sits in the dash loose? Is there another part i'm missing that retains the switch to the dash?
The problem is...you installed the wrong ignition switch. The ignition switch used in 1978/79 is not the same as 1977.
The so called 1977.5 is a 1977, not a 1978. Ford never used the term 1977.5 for anything.
Since you bought the switch from NAPA, what does it really fit? Take it back and get the correct switch...problem solved.
D6TZ11572A .. Ignition Switch (Motorcraft SW1317) / Obsolete
Fits: 1977 F100/350 & Econoline only.
The ignition switch is 1977 only, the other parts are the same 1973/79.
D3TZ10A885A .. Ignition Switch Spacer / Fits between the switch and the dash / Obsolete
Fits: 1973/79 F100/350 / 1978/79 Bronco.
C6OZ11584A .. Ignition Switch Bezel / Available from Ford.
MSRP: $24.13 // FTE sponsor PARTSGUYED.COM price: $17.38.
Fits: 1967/79 F100/350 // 1969/79 Econoline // 1978/79 Bronco // 1966/67 Falcon/Fairlane/Comet // 1967/68 Mustang/Cougar.
Old Feb 19, 2010 | 10:27 AM
Poison Oil Racing
Boy, what a buzz kill! We were having so much fun chatting about this! LOL
96XL
19
Sep 6, 2015 01:52 PM
Weste
Oct 18, 2014 08:40 PM
BPB
Jun 7, 2012 12:07 PM
74 F350 SCS
Nov 30, 2011 06:28 PM
jdv19
Mar 23, 2010 12:14 AM
