hey yu'all havin' trouble with my 76 360....
was cuttin' out and dyin' on me when I pulled a corner, so I rebuilt my carb, thinkin' it might be my float, or needle valve....didn't help, was my first carb re-build, thought maybe I messed up, so I got a rebuilt, installed, and is still doing the same thing!!!!
Anybody have any idea's, cause this shade tree mech, is out of options???!!!
Thanks, but no....all plug wires are secured and tight....checked distributor after motor died, and had spark....replaced elec. fuel pump and now it doesn't die, but still cuts out in third gear between 25 and 30 mph seems okay after shifting to 4th. pulled plugs and polished, re-gapped them, probably need a new set, but would like to hold off may not be possible, will do cap and rotor and wires when I replace the plugs.....is my new carb out of adjustment???? If so, any thoughts on what I need to do to improve performance????
As always, any advice is appreciatted greatly....thank's yu'all!!!!
