re-attaching frame bracket question
Old Feb 5, 2010 | 06:10 PM
My Ford Truck's Avatar
My Ford Truck
Got my frame back from the painter, looks great. I'll post a picture if/when the sun comes out and the snow melts.
Question: I know I need to use grade 8 bolts to re-attach all the mounts/brackets which were removed, but the rivets were an odd size. Do I use 5/16" bolts which have some play or do drill out the holes in the frame and mounts to use 3/8" bolts?
Old Feb 5, 2010 | 06:51 PM
3golfjack's Avatar
3golfjack
I drilled my out and used 3/8" grade 8 bolts. Seemed to be a tighter fit and added a little more strenth.
Old Feb 5, 2010 | 08:10 PM
Old F1's Avatar
Old F1
.................YEP !
Old Feb 5, 2010 | 08:19 PM
Stephen67's Avatar
Stephen67
Drille them out. Anything bolt that needs it's strenght shouldn't ever be loose.
Old Feb 5, 2010 | 08:25 PM
My Ford Truck
That's pretty much what I figured but wanted to make sure first.
THANKS!
Old Feb 6, 2010 | 08:05 AM
49willard's Avatar
49willard
You could re rivet it. On a different vehicle I just finished replacing over 110 bolts with rivets to return to original. In my case I had to plug weld about 70% of the holes and drill before re rivoting. Back when the vehicle was restored, a po had removed the magority of the rivets in the frame probably the rivots had become loose (early roads).
Note: the rivets were either 5/16 or 3/8"
Old Feb 6, 2010 | 06:51 PM
My Ford Truck
110 bolts. Luckily I don't have nearly that many!
So the rivets were either 5/16 or 3/8. An 11/32 bit fits perfect so I'm guessing they were drilled a little oversized and the rivets expand.
Since I don't have very many to replace, I'm going the bolt route.
halaferd
Aug 30, 2013 10:30 AM
packrat56
Jul 8, 2013 03:57 PM
Booner
Apr 29, 2012 08:16 PM
nnero
Feb 2, 2009 08:20 PM
JefflovesF250s
Sep 4, 2007 07:42 PM
