66F250 Core/Rad Support
Old Sep 3, 2007 | 08:31 PM
JefflovesF250s's Avatar
JefflovesF250s
Hey All: Trying to do the economics on rehabing the rad support for my 66F250. Some of you have taken a repop 61-64 support and modified it to fit a 66. What repop supplier did you use and how much was the repop ? How many hours/dollars was required to modify it? Is this the route to go if the bottom flange (to which the frame bolt and rubber bushing attach) is now attached to cancerous sheet metal? Or should I press on with removing the bottom flanges, then insert new metal stitched into the original support and then re-attach the bushing/bolt flanges ? Thx for your input. Jeff
Old Sep 4, 2007 | 07:21 AM
ddavidv's Avatar
ddavidv
Repro supports are all the same one from one manufacturer, so it doesn't matter where you buy it.
Old Sep 4, 2007 | 03:50 PM
JefflovesF250s
Ddavidv: Who are the suppliers in the US that offer them to restorers?
Old Sep 4, 2007 | 07:42 PM
ddavidv's Avatar
ddavidv
NPD, Carolina Classics, Flashback F100s, probably also Dennis Carpenter, MAC's, LMC and some others.
You need to get yourself some catalogs.
thorswhisper
Jun 11, 2011 04:53 PM
JefflovesF250s
Feb 20, 2011 11:22 AM
Bootlegger's Deluxe
Nov 7, 2010 05:56 PM
William
13
Sep 20, 2009 10:25 PM
Putt
Jun 9, 2004 09:27 AM
