Interior Door Handle
Old Feb 2, 2009 | 01:23 PM
nnero's Avatar
nnero
The interior door handle on my truck recently broke where the bracket mounts to the sheet metal behind the door panel. I fixed the issue by drilling two holes in the bracket (underneath the spring) and used self tapping screws to re-attach the bracket to the door. Perhaps this is a good way to prevent this problem from even happening. It was harder getting the door panel back on than anything else. Hope this can help someone.
Old Feb 2, 2009 | 02:06 PM
Jason Lewis's Avatar
Jason Lewis
I did that to it worked great for a year, Then yesterday it broke again i need to replace the door handle cable now.
Old Feb 2, 2009 | 08:05 PM
rambuck's Avatar
rambuck
I had the same problem. My handle just ripped off the frame. It is a flimsy piece of work. My dad just welded the handle piece to the frame. Now it is works great!!!
Old Feb 2, 2009 | 08:20 PM
qman's Avatar
qman
Mine was repaired by welding in a piece of flat bar steel to the flimsy sheet metal and drilling through the flat bar for the clip screw. I've had two 92 trucks and both driver doors ripped like that so I welded all four doors that way.
*2fords*
Jan 5, 2013 05:32 AM
Suber
16
Apr 27, 2008 01:48 AM
cobrasjj
13
Jan 25, 2008 08:15 PM
tomegun543
1997 - 2003 F150
Oct 30, 2006 11:53 PM
mahanson
Sep 8, 2006 09:27 AM
