Crossmember Bolts
Old Aug 24, 2013 | 06:37 PM
halaferd's Avatar
halaferd
Crossmember Bolts
Hey guys, well found some awesome "Easter eggs" that the PO left for me to discover. First we're the 2 rivets broke out where the front crossmember (piece the motor mounts and axel hinge brackets are mounted) attaches to the frame.
Replaced with 2 half inch grade A bolts and did make a diff when driving. After that I thought I would check all rivets, bolts, and nuts. Found more issues.
The brackets where the axle halves hinge, were lose as well. Tried to tighten but one broke and the other 3 were worn to bad to do anything with.
My ? Is, does anyone know where I can get these bolts other than the dealership? I'd use a standard hex head bolt but clearance is an issue.
Thanks for the help
Old Aug 30, 2013 | 02:28 AM
halaferd's Avatar
halaferd
Used 4 1/2" bolts. What a difference. If, when, I buy another truck w the twin-traction beam I will definitely be replacing bushings and checking for lose bolts and cracks.
I have several pics but have never had much luck (patience) posting them. I'll try to get them up.
Old Aug 30, 2013 | 10:30 AM
Perk85F250's Avatar
Perk85F250
I have seen loose bolts and brackets for the front traction axles on a truck with less than 12K miles. Talk about an ANGRY customer! From that day on I always inspected front crossmember brackets and bolts on any 4x4 or 4x2 truck with front axle noise (clunk or knock) complaints. It is not uncommon to find them improperly torqued, loose, missing nuts or broken bolts. Good to hear that you got it fixed!
gbroehl1
Connecticut Chapter
Oct 15, 2009 05:27 PM
Wyokaboy
Dec 15, 2007 10:59 PM
TheWiz427
15
Sep 23, 2007 11:27 AM
Waterchikn
Aftermarket Products
May 16, 2007 01:32 PM
Schmavic
Mar 13, 2004 07:30 PM
