6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Spartan only upgrade
Old Feb 7, 2010 | 08:06 PM
R-T0r21on's Avatar
R-T0r21on
Originally Posted by fg250
R-TOr21on, you said that your MPG wasn't much better w/DPF tunes than stock. I want to do the same thing, what was your mileage stock and then with DPF tunes?
The 150hp DPF on tune felt like there was a little more oomph and better than stock shifting. Actual MPG gain was minimal, maybe 1 MPG better. BTW- Regen frequency remained the same ( about every 700 miles ).
Old Feb 7, 2010 | 08:32 PM
fg250's Avatar
fg250
thanks for the info!
Old Feb 11, 2010 | 12:46 PM
boots1219's Avatar
boots1219
If you only saw a 1 mpg increase from adding the Spartan, what kind of mileage increase did you see after losing the DOC / DPF? I see you have a intake and exhaust...did you do all this at the same time you did the dpf delete or after? Is your EGR still running, or deleted / plated?
Old Feb 11, 2010 | 01:08 PM
R-T0r21on's Avatar
R-T0r21on
I saw approx. another 2-3 MPG after the DOC/DPF delete. Intake & exhaust (DPF back)were done before the truck ever saw Spartan tuning. I believe the EGR is disabled with the Spartan 250 + tunes. I haven't done the EGR block off plates yet. They're on my "to do" list, along with Banks Intercooler, cold side CAC pipe........
Herlface
32
May 16, 2012 04:55 PM
Neil64
Aug 4, 2010 01:11 PM
boots1219
Mar 16, 2010 08:03 PM
agoose33
Jan 4, 2010 12:37 AM
GM243
18
Jul 31, 2008 10:42 AM
