Try-Y headers
Old Aug 19, 1999 | 12:58 PM
SteveT's Avatar
SteveT
Try-Y headers
Does anyone know where I could locate a set of Try-Y headers, for my 1980 F-150 4x4 400M??? I've tryed all the most popular companys, and had no luck. I'm looking for the Try-Y design for their low-end torque producing characteristics. Any ideas of places to try?
Thanks!
SteveT
Old Aug 19, 1999 | 05:00 PM
390fe's Avatar
390fe
Try-Y headers
After a quick glance at the latest Jegs cataloge, on page 57-U, I found a slip on collector that'll turn a standard header into a tri-y. Cost about $100 bucks.
Old Aug 19, 1999 | 05:11 PM
390fe's Avatar
390fe
Try-Y headers
Also check out page 61-U. Pulse Tech makes a set of slip ons for about 73 to $100 bucks.
Old Aug 19, 1999 | 05:17 PM
Chubby's Avatar
Chubby
Try-Y headers
What exactly is a tri - y header?
Old Aug 19, 1999 | 06:02 PM
SteveT's Avatar
SteveT
Try-Y headers
Chubby, as I understand it, Tri-Y headers are known for their low end torque building Characteristics, due to there inherent "scavaging" effect. They go from 4 into 2 then 2 into 1. If you can picture that sequence, it actually creates 3 Y's. Hence "Tri-Y" Hope that helps!
SteveT
Old Aug 20, 1999 | 08:35 PM
BigRebel's Avatar
BigRebel
Try-Y headers
Old Jan 10, 2005 | 09:59 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Thumbs up tri-y
Hi all, new to the forum. I got my tri-y from stans headers www.stans-headers.com . The are a good fit. I opted out of the crome in lue of hpc coatings. Lets not even get me started on that. Hope this helps
Old Jan 10, 2005 | 10:45 AM
ivanribic's Avatar
ivanribic
Good call 73. I was going to suggest Stans also. He does EXCELLENT work, probably some of the highest quality headers on the market. I'm just hoping that Steve found those headers after 5 years.
Welcome to FTE!
Old Jan 10, 2005 | 11:17 AM
73 hi-boy 428 fe
lol,I did not even look at the date. That was the first time I found the site. It looks to be a great site. I take it it starts at 1 and the older the number the older the date. Thanks for the heads up. 73 f250 reg cab 428/np435/np205 dana 44 closed knuckle (looking to upgrade need power brakes/disk and power steering)/ 33 ss thornbirds.
Old Jan 10, 2005 | 12:17 PM
ivanribic's Avatar
ivanribic
No problem man, just had to give you a hard time about it. FTE is a great site with all the resources you could ask for to help get these old trucks into shape. If you get a chance join the Kansas chapter here too. They're good guys and can help you out locally if you need.
lesoster
37
Jan 10, 2020 02:18 AM
864604X4
Aug 25, 2010 11:02 AM
dave98
Jul 24, 2003 05:54 PM
SteveT
Aug 24, 1999 06:38 PM
