How to drain a 9"
Old Jan 9, 2005 | 12:48 AM
ftballman125's Avatar
ftballman125
How to drain a 9"
Well i bought the gasket, and the fluid, but when i set down to change the fluid in my 9" rear i was at a loss as to exactly how to drain it. Do i have to undo the bolts and break the gasket seal? Or is there some other unseen way? There is no drain plug, simply a fill. I looked at it wouldnt be very easy to suck it dry.
Thanks for the advice in advance.
Nick
Old Jan 9, 2005 | 01:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pull the driveshaft, and axles, unbolt the pig. Take the "opportunity" to inspect the gears...
I suppose you could also pull one axle and tip the truck over...
Old Jan 9, 2005 | 01:29 AM
ftballman125
no other way??
Old Jan 9, 2005 | 01:36 AM
beeboy's Avatar
beeboy
You can drill a drain hole, tap it and plug it. The rush of oil will keep shavings from getting in the pumpkin. How to keep your drill clean though remains a mystery to me.
I like the idea of tipping the truck on its side though..
Old Jan 9, 2005 | 01:49 AM
fordlover's Avatar
fordlover
u could try one of the pumps used to remove oil from an in-board boat motor. I was thinking about doing that this summer when I change my cars fluid.
Ryan
Old Jan 9, 2005 | 08:05 AM
towtruck's Avatar
towtruck
I just use a hand pump and suck it out.
Old Jan 9, 2005 | 09:02 AM
MBDiagMan's Avatar
MBDiagMan
It only needs changing at about 100,000 mile intervals. If you are at that point, I agree with Torque1st in that it's not a bad idea to just pull the axles, drop the pumpkin and inspect everything.
That said, unless you're pulling a 15,000 pound trailer all the time, forget and leave a 4X4 in 4WD on the pavement, or drag racing, that thing will probably go 500,000 miles as long as no lubricant leaks out. If it does, then there is a leak that you need to tend to anyway. In that case it's time to pull it apart.
Good luck,
Doc
Old Jan 9, 2005 | 11:04 AM
79driver's Avatar
79driver
Mine has a drain plug that was put into the bottom of it about 15 years ago. Sure made it alot easier to drain.
Old Jan 9, 2005 | 11:50 AM
fasthauler's Avatar
fasthauler
I love this thread, you guy's are a bunch of comedians. I pitty the poor fool that takes you seriously.
Old Jan 9, 2005 | 12:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Who says we were kidding???
I have drilled and tapped housings before but being a machinist I had the tools and skills to do so. Always use a magnetic drain plug even if you have to make your own.
Have any of you guys ever figured out how many hours of operation 100,000 miles is? You might be surprised at how few that number might be. Then compare that number to industrial machinery operating 24/7.
Old Jan 9, 2005 | 12:23 PM
fasthauler's Avatar
fasthauler
To Torque1st, I change my rear end (lube) every 50k, I pull a 5th wheel that is pretty heavy and don't want to take any chances. It isn't very expensive to change and isn't a lot of work if you dont mind getting a little dirty.
I did put a drain plug in the tranny and an external cooler & filter and change the fluid every 25k. The tranny fluid gets pretty cruddy even with all of the filtering and cooling that it goes through. I thought about putting a drain plug in the rear end, but never got around to it.
I appreciate all that you guy's do to keep this website going. Gary
Old Jan 9, 2005 | 02:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks!
That tranny fluid filter and cooler is a great thing to do. What type of filter did you use? The regular transmission filter is totally inadequate for the application. Some transmissions only have a crude screen.
The drain plug is easy to put in if you have some metalworking skills.
Old Jan 9, 2005 | 05:03 PM
Mil1ion's Avatar
Mil1ion
Eric, He meant the tipping the truck over part as being the comedic part.
In the meantime, that's exactly how I drained an axle once.
Old Jan 9, 2005 | 07:42 PM
TreeTrimmer17's Avatar
TreeTrimmer17
pull fill plug out and buy a pump or find some vacume line and put it on momma's turkey baster and suck it out. just make sure you dont leave it around where she can see it. I was in the dog house for awhile on that one.
Old Jan 10, 2005 | 09:52 AM
uemf's Avatar
uemf
turkey baster fun
Yummy !! I can just tast that 90 weight now .
I know what I'm basting my turkey with next thanksgiving... if I can wait that long!
(maybe I'll put the baster out in the garage for the wife to find just for fun(a little masocistic, but fun).
