Connecticut Chapter Join Chapter, Leader:
February B/S thread
Old Feb 17, 2010 | 04:02 PM
  #406
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Good evening everyone.
Old Feb 17, 2010 | 04:08 PM
  #407
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Good Afternoon.....
Old Feb 17, 2010 | 04:11 PM
  #408
tbenks's Avatar
tbenks
good evening.......
  #409
Nice Work Truck's Avatar
Nice Work Truck
Afternoon guys.
I thought it was supposed to be sunny today.
Old Feb 17, 2010 | 04:12 PM
  #410
gbroehl1's Avatar
gbroehl1
Afternoon everyone.
Old Feb 17, 2010 | 04:40 PM
  #411
StreamlineGT's Avatar
StreamlineGT
Hooter's in Manchester at 6:30. What are you guys doing tonight?
Old Feb 17, 2010 | 04:48 PM
  #412
sddesigns's Avatar
sddesigns
FTE Emeritus
Too far for me!
  #413
tbenks's Avatar
tbenks
man i drove by that hooters earlier today
Old Feb 17, 2010 | 05:07 PM
  #414
Aerocell4x4
Update on my van.
I might have it next week.
Today the car rental agency called me and asked me to swing by as I've had their car for over two months now.
With that in mind I first swung by the dealership and said to them:
'eh the rental agency called ... so why don't you call them first before I swing by as the agency is likely going to want to know how much longer I'm likely to need their car and you'd be more convincing than me.'
The dealership said to me 'eh your van is up on the lift you want to see it?' and I said eh 'when its done,' but they insisted so I went and looked and chatted with the mechanic.
The van has been there so long that they forgot a lot of the 'little stuff'
The differentials & axles are all together, and so too is the steering gear.
I see you didn't install the polyurethane boots & bushings as I asked. And now I suppose its a done deal
no drain plug for each differential. To which he said 'I haven't filled the differentials yet so I'll pull the covers and drill & tap.
I'm thinking oh so if they were filled then that would be a done deal too.
He points out that my steering stabilizers are leaking, I take it that my new steering stabilizers are still sitting on the front seat?
He notes that one Bilstien shock is missing hardware
I said I'd look into it. I emailed them back the North Haven warehouse info and mentioned that why didn't they check contents back in January?
I wonder why they can't rob the hardware for a 'generic' shock?
I was told that they had to send out the axles to be cut to fit. I said of course, they come in short medium & long lengths with plentiful spline cuts just for that reason. I reminded the service writer, that was why I had attached the spline end beveling & clearance document to the work order.
Oh ya he says.
I'm wondering now if they followed that instruction. It's appears to me that the mechanic probably has done differentials before but not aftermarket axles, and that the dealership didn't have a chop saw.
He asks where is the compressor and where do I want it mounted.
I said, remember I asked that you just plug the airline connections and don't run any wiring as I can't afford the Oasis Compressor, especially considering how long I've had the rental car. I said at this point I'll likely zip screw into the back of the van a tire air-tank and live with that.
We talked about the speedometer recalibration, and they said that the Ford program doesn't have a 5.13 selection. I emailed them back to fake it, to use another gear and tire combination to come close, and that by my calcs. I'm only going to be about four mph slower than an indicated 55mph so I suppose I can live with that until I can get my van through emissions.
I asked about the wheel stud length being long enough? he said they are the longest available, but he hadn't check the stacking height to see if everything will mount to the hub. Automatic balancer disc, tophat, and the thicker rim steel.
After the dealership I stopped in at the SCT guy that I got my tuner from and asked about the emissions and the speedometer.
The SCT guy said I have to run the van stock for about a week before emission testing so that all the learning settles out, else I'll fail emissions
That I should bring him my tuner and he would make the adjustments for the speedometer, as he doesn't unlock the speedometer section of the tuners.
So tomorrow I'll swing by the dealership and restore the van to stock so I can take my tuner with me and drop it off on my way into work.
The shop still has to relieve the body to clear the tires and add turning stop blocks as necessary which they intend to spot weld in place.
I asked about the sensitivity to welding of the piece that has the original stop? The mechanic said that, well Quigley had welded up the adapters on the axle tubes so it must be ok. I don't know though he's looking at the flat on the stub of the yoke that comes out of the axle tube and not the rod that extends out of the hub. I hope its a no-never-mind.
Old Feb 17, 2010 | 05:21 PM
  #415
gbroehl1's Avatar
gbroehl1
Good to here they are finally wrapping it up.
Old Feb 17, 2010 | 05:22 PM
  #416
7.3 Rocket's Avatar
7.3 Rocket
Still thinking it's worth it all, Dave?
I couldn't go that long without having my truck that's for sure. I'd be missing out on a lot of work.
Old Feb 17, 2010 | 05:26 PM
  #417
BIGKEN's Avatar
BIGKEN
Howdy CT...what's happening???
Old Feb 17, 2010 | 06:21 PM
  #418
Aerocell4x4
Nice picture of the baby Greg.
Old Feb 17, 2010 | 06:23 PM
  #419
Aerocell4x4
Ya Pete, I had brought that up with the dealership previously.
Mentioning the drifting pinion shafts in the 1st - reverse planetary set putting snowplow operators out of business a few Winters ago.
Old Feb 17, 2010 | 06:24 PM
  #420
Aerocell4x4
Hi Ken.
Just another quiet night here at work.
Last night we ran the units for a couple hours.
