Finished the pipe wall today. There was a little adjusting from the original print, but mostly stayed the same. I am going to put e-track on the body seam under the cabinet doors on the left, and same on the right. I also want to put e-track on the bottom left, and line all the cased tools on the left hand side and strap them in. I decided on the e-track after trying to go home from BLowes with a finish sanded piece of birch plywood, leaning on the left wall. It fell over. Now I will have a means to strap it in, leaning on the wall.
Brandon the truck looks good.
Have you ever thought of a Little Giant ladder in place of having the 3 steps?
um, no. I had a long drawn out explaination, but it was lost in the internets somewhere. so, the answer is just no. If you would like to know why, I will type it out again. Basically just too heavy.
