92 Explorer auto transmission HELP!!!!
Old Jan 31, 2010 | 06:37 PM
BRONC-OH's Avatar
BRONC-OH
Son ran the 92 Eddie Bauer Explorer with very low trans fluid. Left him stranded and wouldn't go into gear.
I put fluid in and now it takes a while, but slowly will drop into reverse, low, 2, and drive. However, it won't go into OD, it just revs as if in neutral.
Like I said, when you put it into gear, it thinks about it for a while, then finally will slowly go into gear.
Once in drive, it will shift through the gears OK. But OD is not working at all.
HOW BAD IS THIS?!?!? Please be gentle.
Old Jan 31, 2010 | 09:05 PM
Moto Mel's Avatar
Moto Mel
Sorry, nothing gentle to say here.
There is a trans rebuild or replacement in your immediate future. You now have burnt clutches, both fibers and steels, burnt band(s) and drum, worn front pump, torque converter and probably more. If I were you I'd start checking the salvage yards for a "clunker" as they only ruined the engines. Your nearest Pick-N-Pull would be your least expensive option at about $100/150 Vs around $300 to $450. Good luck with it.
Old Feb 1, 2010 | 02:36 PM
aquanaut20's Avatar
aquanaut20
You will be looking for an A4LD, they do not like to be abused, best change it before you are left stranded.
Old Feb 2, 2010 | 09:27 AM
KhanTyranitar's Avatar
KhanTyranitar
Yeah, low fluid can be the death sentence. Causes weak engagement and slipping equivalent to tens of thousands of hard miles.
MrMontana
Aug 26, 2013 05:14 PM
TA Dave
Feb 10, 2011 11:18 PM
bigben4x
Dec 9, 2006 04:15 PM
buckskin
1997 - 2003 F150
Dec 31, 2003 05:20 PM
