I guess you might want to hook up a gauge to the test port and see if your generating any pressure. Normal idle pressure in part is about 55-65psi. If no pressure then you're going to have to pull the pan and ensure the filter hasn't dislodged or is plugged. If it's plugged you've got other problems that will warrant a pull. If everything is in order then, I'm sorry to say, you'll have to drop it and find out what's broke. Could be several things.
Maybe someone else can recommend something before you pull but its not looking good.
