MBRP Install Help!
Old Mar 13, 2009 | 09:44 PM
Jbru167's Avatar
Jbru167
MBRP Install Help!
I am trying to remove my stock exhaust from my 03 6.0 PSD. The down pipe is wrapped in a thick tin-foil/heat tape with metal clamps in different random spots. I have cut the down pipe in front of the transmission cross member and can not get the down pipe out!
Do I need to cut the pipe again closer to the engine or do I have to rip the rest of this foil crap off?
Any tips on putting the new down pipe on looks like it is going to be difficult.
Old Mar 14, 2009 | 03:47 AM
officer131's Avatar
officer131
I have the 7.3 diesel. I didnt have any foil wrap on mine, but I did have to use a torch to heat the clamp enough so it would break away fron the flange on the turbo. Not sure why its a big problem for you.
Old Mar 14, 2009 | 08:03 AM
Jbru167's Avatar
Jbru167
my flange came off very easily but can't get the pip out with this wrap all over it.
Old Mar 14, 2009 | 06:16 PM
DSMMH's Avatar
DSMMH
For safety, you should remove the insulation. I cut the insulation clamps then removed enough insulation so I could cut the OEM down pipe about 4" above the frame. You basically have to cut the down pipe at the first turn after the pipe comes straight down. If you use a saws all, use a fine tooth metal cut blade. A medium or course tooth blade will be ugly and you may get hurt.
DSMMH
dans 51 f2
Sep 12, 2015 05:35 AM
genscripter
15
May 2, 2015 10:46 PM
timmyboy76
34
Nov 8, 2012 11:03 AM
seanmconroy
Jan 31, 2012 03:24 PM
Jbru167
Mar 15, 2009 11:26 AM
