Foil Delete & WW
Old Mar 2, 2008 | 11:05 PM
griff64's Avatar
griff64
Foil Delete & WW
Hi all, did FD & WW last weekend and it made a big difference, it sure does whistle now. Thanks to everybody for all the great mods, I love my TRUCK. Dave
Old Mar 3, 2008 | 06:51 AM
Izzy351's Avatar
Izzy351
Congrats!! Sounds good, doesn't it???
Old Mar 3, 2008 | 06:53 AM
greedy737's Avatar
greedy737
Was it hard to get the foil off!!
Old Mar 3, 2008 | 06:56 AM
1996pwrstrk's Avatar
1996pwrstrk
Just wait till you pull a load with it , I hauled about 17 tons of gravel Fri for my drive and it was warm enough to have my windows down MAN did it sound sweet!!!!!!!!!!!!!
Old Mar 3, 2008 | 07:01 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Did the same thing this weekend and wow does that wheel scream. I love it
Old Mar 3, 2008 | 07:53 AM
Izzy351's Avatar
Izzy351
17 TONS?? That's 34k + ~8k of truck, or about twice its rating. Did you pull that stuff any distance? There was a guy that pulled a whole mobile home that posted pics here, but it wasn't that far and only on the back roads. That's the biggest load I've heard of (besides the trailer house), so that's why I'm asking...
Old Mar 3, 2008 | 08:02 AM
Izzy351's Avatar
Izzy351
Not really. Use the adhesive remover and it's not a bad job at all. Here's the thread I started on it way back when:
https://www.ford-trucks.com/forums/5...nsulation.html
Old Mar 3, 2008 | 08:07 AM
randomhero1172's Avatar
randomhero1172
I Missed that thread, so i left the ic pipe on and left the job with cut up hands. But the foil was off
Old Mar 3, 2008 | 09:12 AM
Izzy351's Avatar
Izzy351
Dude!! That must've really sucked! How did you get it clean??
Old Mar 3, 2008 | 09:37 AM
ggirten's Avatar
ggirten
We did my son's on Friday. It was like skinning a snake. Foil wasn't bad, but the insulation and glue was nasty. We didn't have any remove, so I used a propane torch and heated the glue slighty, then a non abrasive wheel on a drill. Took a while, but it all came off. You can really hear the turbo whine.
Old Mar 3, 2008 | 09:57 AM
griff64's Avatar
griff64
Make sure you use the thick stuff and get some thick rubber gloves, it burns really bad if you get it on ya, and i used a plastic putty knife to scrape it, get 2 they kind of melt. keep it wet with the remover and it comes off pretty easy. Dave
Old Mar 3, 2008 | 11:34 AM
1996pwrstrk
No no no I didn't do it all at once the stupid dump trailer I rented was suposed to handle 5 ton at a time but it couldn't . THe first load was 5 ton after that I kept it at 3 ton or the hoist wouldn't work to tilt the bed. After I was done I had to replace all the brake lines on the trailer ( surge brakes ) they had the lines run in between the axle and frame and when I put 5 ton on it I snapped them all because the frame sat down on the axles.
Old Mar 3, 2008 | 12:42 PM
Izzy351's Avatar
Izzy351
lmao.... Oh, okay. I was about to give you big kudos for having some serious testicular fortitude....
Old Mar 3, 2008 | 04:05 PM
randomhero1172
Well im a pretty small dude, around 5'7" - 155 . I i just posted up on the entire engine and worked it off Slowly! then used some wd-40 when i finished ripping off the foil and as much insulation as i could. Took a good 55 minutes. Wasn't terrible, but id much rather be moding something else
48_F1
Projects
70
Mar 1, 2021 02:55 PM
WW2N
Nov 26, 2014 01:04 PM
outlawbob
1978 - 1996 Big Bronco
28
Sep 13, 2012 04:45 PM
Gage2502
Aug 24, 2012 06:16 PM
indebt
16
Jun 10, 2008 11:07 AM
