Testing coolant
Old Jan 29, 2010 | 05:30 PM
teppler's Avatar
teppler
Testing coolant
Where do I go to get coolant tested?
Old Jan 29, 2010 | 06:15 PM
bismic's Avatar
bismic
The dealership can do it. You can also get test strips from Napa or fleetpride.
If your coolant has gone 50k miles and hasn't been changed, I would just flush it, clean it w/ VC-9 (thanks 69cj) and add new. This coolant was advertised as 100k miles service life, but it does not protect well past 50k.
Edit (more info):
TEST your coolant: Fleetguard DCA4 Test Strip Kit CC2602A (FleetPride or DieselManor): 800 ppm minimum nitrite level
Ford part number for test kit: 328-00001 or call Rotunda - Rotunda 3-way heavy-duty antifreeze test strip kit (1-800-Rotunda (768-8632) Option 2)
Also - check the expiration date on the test strips - so not get them or use them if they are past this date.
Old Jan 29, 2010 | 06:20 PM
69cj's Avatar
69cj
Edit (more info):
Don't forget the 5 year limitation on it also.
Old Jan 29, 2010 | 06:37 PM
Btravelen's Avatar
Btravelen
Acustrip
http://www.acustrip.com/CTS-3_Retail_Order_Form.pdf
Take Care
HowieE
Aug 5, 2016 08:28 AM
sgrol
6.7L Power Stroke Diesel
Sep 30, 2014 07:54 AM
caere
Dec 25, 2010 10:29 AM
quaders4ever97
Dec 17, 2008 01:29 PM
mjtpolice76
69
Jan 15, 2006 01:43 AM
