Coolant test strips
Old Dec 21, 2010 | 03:58 PM
caere's Avatar
caere
Coolant test strips
So got the test strips from NAPA. The guy said they measure pH. So what is the desired pH and what would combustion gases in coolant be?
Thx
Old Dec 21, 2010 | 04:36 PM
ljutic ss's Avatar
ljutic ss
The test strips you got are more then likely for testing nitrite levels, which should be 1200 ppm. They have nothing to do with exhaust in the coolant. On the container does it show 3 graphs? which are nitrite, percent glycol, and PH.
Old Dec 21, 2010 | 04:44 PM
caere's Avatar
caere
Two graphs:
Glycol
pH
Old Dec 21, 2010 | 04:48 PM
caere's Avatar
caere
I also picked up a combustion leak fluid thingy. Supposed to put some fluid into this tube. Stick one end into bottle neck and the other end needs vacuum on it. Supposed to let the air bubbles run through fluid. If it turns yellow you have headgasket problems. Doesn't say if for gas or diesel. I assume Combustion gases are about the same whether diesel or gas. And diesel has higher no2?
Old Dec 21, 2010 | 04:51 PM
caere's Avatar
caere
ph read 7.5
Old Dec 21, 2010 | 05:25 PM
ljutic ss's Avatar
ljutic ss
The Wix test strips I use and are sold at NAPA stores are for diesel coolant testing. Besides the PH and glycol you also check the nitrite levels which are very important in diesel engines. The strips you have are probably for gas engine cooling systems.
Old Dec 21, 2010 | 06:04 PM
caere's Avatar
caere
Yea I suppose that makes sense. But then guy seemed confused what I was asking for. He found them and I asked if there were any others. He said no.
Old Dec 21, 2010 | 06:57 PM
bpounds's Avatar
bpounds
It would be easier and less confusing to just buy the official Ford nitrite test strips from this place:
CTS-3 Three-Way Antifreeze Specifications
Old Dec 25, 2010 | 09:44 AM
taz man's Avatar
taz man
went to my local Ford dealer and they did not even carry them or use them they said, will try another dealer on monday.
Old Dec 25, 2010 | 10:29 AM
ljutic ss's Avatar
ljutic ss
If you go to Ebay and type in coolant test strips, there is a person selling the 4 pack of Wix fil4105 diesel test strips for $6 delivered. Wix might have discontinued the 4 pack but still sell the 50 pack which is about $30
strokeithard
16
Mar 2, 2017 02:41 PM
Hank85713
May 14, 2016 03:15 PM
Crewcab Turbo
May 28, 2012 10:38 PM
ruschejj
6.7L Power Stroke Diesel
Jul 24, 2011 07:50 AM
Andywk
Mar 14, 2003 09:05 PM
