Overhead Compass and Temp Quit Working
Old Jan 30, 2012 | 06:11 PM
  #31
TABLESAWTIM's Avatar
TABLESAWTIM
8th Gear
Compass/Temperature in Instrument Cluster
Hello all,
I have had a dead Compass/Temperature module for a couple years, and mine is in the instrument cluster, in between the tach and speedometer.
Any ideas before I go in?
Thank you, Tim
_____________________
2006 Expedition XLT, 110k Miles
Old Jan 15, 2013 | 10:14 AM
  #32
RealTrife's Avatar
RealTrife
Originally Posted by BoBoBill
I was able to get the temperature and compass to work by soldering the chip. But now the temperature gauge reads 90 degrees and it wont change. Is there a reset button I need to push? If not what can I do now.
Thanks
I know you posted this some time ago but what did you do to correct the temperature problem? I am experiencing the same issue mine always displays as 140 degrees
Old Aug 17, 2013 | 05:56 PM
  #33
tapper95's Avatar
tapper95
Just fixed mine in about 30 minutes.... with shaky hands and a full size soldering iron. I used a metal pick to guide the solder. Ugly but effective. It was one of the wafers numbered 510. I didn't see any broken joints so I checked for loose pieces and lifted up that wafer. Once I resoldered the wafer to the board, I put it back together, found one extra part so I dismantled and put it back together again.... and it's like 1999 all over again.... now I know where I'm going.
Old Nov 24, 2014 | 04:06 PM
  #34
Quicktherapy's Avatar
Quicktherapy
compass repair
Originally Posted by hotrodford87
I found a guy on Ebay that 'rebuilds' them. You can order one for your specific vehicle from him and it costs about 1/2 the price of a new one + a core charge. When you return your rebuilable unit to him, he refunds the core charge.
Hey hotrodford87 I need the guy you found on ebay to fix a compass I have that doesn't work. And also do you know which fuse # number operates this instument? Please help desperate....lol
Old Nov 24, 2014 | 10:32 PM
  #35
alloro's Avatar
alloro
Originally Posted by Quicktherapy
also do you know which fuse # number operates this instrument?
Year, expedition, navigator?
Old Nov 25, 2014 | 01:03 PM
  #36
Quicktherapy
Sorry. 2000 Ford Expedition XLT 4.6
Old Nov 25, 2014 | 07:24 PM
  #37
Quicktherapy
Overhead compass &Temp
In need of your guy on eBay who repairs Compass &Temp please shoot me the info to contact him.... Thanks...working desperately... lol
Old Nov 26, 2014 | 05:34 AM
  #38
alwaysfords41's Avatar
alwaysfords41
You would be better served sending him an email. There are also at least two other places with links in the thread for places that fix them.
Old Nov 26, 2014 | 12:41 PM
  #39
alloro's Avatar
alloro
Checks fuses 2 and 6 under the dash.
Old Mar 7, 2015 | 05:20 PM
  #40
BGE541's Avatar
BGE541
Anyone know how to get a replacement display and if it canbe soldered onto a good board? Mines FUBAR... burn mark ect
Old Mar 8, 2015 | 12:58 PM
  #41
alloro's Avatar
alloro
Getting just the display could be tough if not impossible. You can however get the whole module used off eBay or here: Car-Part.com--Used Auto Parts Market
Old Jun 16, 2016 | 07:03 PM
  #42
teamsolu's Avatar
teamsolu
Hi there - My compass display is not working, however, neither are the courtesy lights. I am thinking it is a fuse. Please - does anyone know of a fuse that can cause both to be out? Thank you
Old Jul 31, 2016 | 02:22 AM
  #43
Rugby415's Avatar
Rugby415
03 F350 6.0 CC lariat
Hey everyone, I was reading this thread since my comp/mpg/temp readout stopped working. I took off the console cover (I started pulling on the end pointing towards rear of truck) and it came out with a little force but no broken tabs. The first thing I did was disconnect then reconnect the plug on the side of the readout a couple of times, turned my truck on and it started working again. Hopefully it's that's easy for some of you!
Old Jan 20, 2017 | 03:58 PM
  #44
xXCaptain88Xx's Avatar
xXCaptain88Xx
Stuck, and can't get the circuit board separated from the mode e/m housing
Originally Posted by kailor
I just went outside and removed the unit from the vehicle. Mine is compass and temperature only. The first pic shows a wafer of sorts that is out of place (follow the toothpick). Is this a resistor?
The second pic shows where I slid the wafer back to where it should be.
Upon initial examination, the circuit board looked good. A closer look revealed that a wafer labeled "510" had one corner kind of raised or sticking up. I pressed down on the raised corner ever so lightly and the wafer moved off of its bed. It had indeed come unsoldered. How would I go about soldering this back? I may just take it to a local electronics store that has been around for 60 years.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
tvk
xcrsp440
Jun 18, 2017 05:00 AM
kailor
Jun 18, 2016 07:41 AM
GeorgeNteri
May 2, 2016 10:42 AM
cwordsmith
18
Apr 3, 2016 09:20 PM
mmenzies
Feb 9, 2016 07:33 PM
