Julie, Looking at your photos, I was wondering if the shoe with the shorter lining was supposed to be on the front. I am a newbie and thought that the longer lining was the primary shoe that should be on the front. Do I have this backwards? Thanks, Steve
Also....Is there a $5 self adjusting upgrade kit for the 51 F1? Where do I get one and are they any good?
Short shoe goes on the front. These pictures were taken when I was repairing the front end. The bottom picture is of the passenger side, the other two are drivers side, I should have pointed that out. So the shoes are installed correctly in the photo's.
Here is a picture of the brakes with the self adjust mechanism (passenger side). Note the extra parts and different arrangement....this is probably what Hillbilly was refering to when he mentioned parts missing. Just FYI, self adjusting brakes were introduced in 1961:
The easy way to remember where the shoes go is, the forces are meant to be balanced shoe-to-shoe. The front shoes are self-energizing so they don't need to be as long as a rear shoe to generate the same force. Or conversely, if the big shoes were to the front, tapping the brakes would throw you thru the windshield!
Julie, I see you've converted to self-adjusting; did you have to buy newer-style shoes to get the holes for the hardware?
Does someone do a kit? I checked out all the usual suspects (Mid Fifty ,LMC etc ) but no luck.
Or can you just get a '61 set of parts from NAPA?
Thanks as usual.
Chris
Saving threads (my previous question to you):
Off subject and if anyone else needs to know - if you are using Firefox all
you need to do to save threads is to Bookmark them. you can also subscribe to the main page (in the bookmark menue) and right click it every time you visit it and it will update the subscription with all the latest posts listed.
Thanks for your help on that too.
I can't comment on 48-52 stuff, but since 53-60 brakes are the same.... I converted my 1959 using parts I ordered the kit for a 1966 f-100. My shoes already had the proper holes. Having worked on a 1963, the self adjuster's didn't come out until 64 or 65. I did not convert the rears yet.
Originally Posted by cwordsmith
Hey Julie,
Where did you get the self adjusters from?
Thanks as usual.
Chris
Sorry guys, but I haven't converted to self adjusting brakes, I just stole the photo off another thread to use as an example. (And of course now I can't find the thread it was in - but I'll keep looking)!
Edit note - these might be helpful. Second post says you can get the stuff at NAPA:
