Bought a 2004 f350 lariat last fall. Overhead console was missing. Finally got around to replacing the display. Temp, compass works fine, but mileage and distance to empty are way off.
Display typically shows 13.5mpg but when manually calculating am usually closer to 17. Distance to empty is way off as well.
I did some research but didn't find much on how to recalibrate it.
Any chance thoughts?
They can take time to learn your driving habits for one
thing and for the most part they are never correct.
They can get better on long drives on the freeway
where you don't have a lot of stop and go. The only other
thing I am not sure about is if they require any module
programming or not. Ed or one of his people at FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
might know the answer to that one. I have a feeling that it may
be part o the cluster programming. But like I said I am not sure.
I was thinking programming also (FICM programming anyway). FICM programming seems to make a difference on calculated fuel economy and miles to empty - at least mine did. The difference between actual and indicated got worse w/ my tuned FICMs. I went from a .5 mpg offset to 1.5 mpg (+ a little)
