Overhead Compass and Temperature Quit Working...Again!
Old Jan 31, 2016 | 10:57 AM
kailor's Avatar
kailor
My overhead compass and temperature quit working again. The first fix (I posted on this topic) lasted 6 years. All solder joints look good. This time the readout faded from working to barely readable to not visible at all. The book shows this to be controlled by relay/fuse #2 at the inside fuse compartment near E-brake pedal, which also controls the PCM module! Can I assume that since everything else electronic is in normal working order that the problem is not this fuse? Thanks in advance.
Old Jan 31, 2016 | 01:19 PM
Skauber's Avatar
Skauber
Might be that the display itself finally gave up, or perhaps more likely something in the driver circuit. Confirm if the console is receiving power or not. If it is, then the problem is internally and it may have to be repaired or replaced.
Old Jan 31, 2016 | 02:17 PM
kailor's Avatar
kailor
Thanks Skauber.
Old Jun 16, 2016 | 07:06 PM
teamsolu's Avatar
teamsolu
Hi there - My compass and temp display, its two lights, and all courtesy lights are out. Does anyone know of a fuse that can cause this? I checked the fuses on the left side of the steering wheel, could not find one that was bad. Not sure where else to look.
Thanks in advance for the help.
2003 Ford Explorer Sport Trac
6 cyl, 4 dr, 2 wheel dr, XLT
Last edited by teamsolu; Jun 17, 2016 at 09:23 PM. Reason: type of vehicle missing
Old Jun 17, 2016 | 12:03 AM
alloro's Avatar
alloro
Are we supposed to guess which vehicle you have?
Old Jun 17, 2016 | 10:54 AM
teamsolu's Avatar
teamsolu
Sorry - I have a 2003 Ford Explorer Sport Trac, 2 wheel drive, 6 cyl, XLT
Old Jun 18, 2016 | 07:41 AM
alloro's Avatar
alloro
This is the expedition/navigator forum, you want the explorer forum here: Explorer, Sport Trac, Mountaineer & Aviator - Ford Truck Enthusiasts Forums
Alex from GA
Nov 13, 2013 02:54 PM
TDGRIND
Electrical Systems/Wiring
Oct 20, 2009 06:51 PM
Skoda
Dec 2, 2007 10:23 PM
Jah5EX02
Dec 4, 2006 01:30 PM
