Power window motor.....
Old Jan 26, 2010 | 04:57 PM
KiwiFord's Avatar
KiwiFord
I may need a power window motor, my truck is a 77, but I am told the earliest they had power windows was 81, can anyone help with a power window motor that works, or part number?
It is for the drivers door on an F150.
Thanks,
Shane
Old Jan 26, 2010 | 05:10 PM
ChaseTruck754's Avatar
ChaseTruck754
search. It's been covered a few times and multiple ways of doing it has been posted. Someone even makes a kit but I forget who.
Old Jan 26, 2010 | 05:48 PM
alconk's Avatar
alconk
Thanks,
Shane
Do you have a picture of the switches you used? I'd like to see your setup.
Thanks!
Old Jan 26, 2010 | 07:04 PM
KiwiFord's Avatar
KiwiFord
Sorry, I wasn't too clear above. The conversion has been done, a motor has crapped out. It looks like they used a later model Ford set up, so I don't need a kit, just a motor. Most of the after market kits LMC etc drive the standard regulator, whereas mine is a proper power window set up. So, an aftermarket motor won't work, I need a genuine Ford one, hence the original post.
I will try to get a pic up of the switch.
Cheers,
Shane
Old Jan 26, 2010 | 07:16 PM
ChaseTruck754
Ahh - got it now.
It would really help if you knew what was put in your truck. I have heard people using 80's Van stuff, and then this guy used parts/motors out of an 86 bronco.
1973 Ford F100 4x2 - '73 F100
I'm not sure how early on power windows came in but I would think the motors would be the same from the early 80's up into the early 90's - at least in the F series and broncos. Calling the parts dept. at Ford may yield some answers.
Old Jan 26, 2010 | 07:22 PM
KiwiFord's Avatar
KiwiFord
No doubt it would...
I have no doubt it would, but as I am in New Zealand....and they were never officially bought down here it is a bit tricky, plus Ford NZ add a truckload of mark up to any US parts....
I have looked at a wreckers, and a late model Ford Falcon one may work....btw, go have a look at the Ford Australia site, and check out the Falcon, especially the XR series, yup, rear wheel drive too.
Shane
Old Jan 26, 2010 | 07:25 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Cheers,
Shane
Are you sure the motor is shot? I have never seen a ford motor burn up. It is usually just the gear in the gearbox. Can find a gear rebuild kit in every parts store.
Old Jan 27, 2010 | 12:12 AM
1977f250's Avatar
1977f250
Not sure if Ford motor but by far the best one I have seen.Ford F Series Power Window Kit: A1 Electric Online Store
harley3348
Electrical Systems/Wiring
Apr 20, 2014 11:49 AM
teamlx88
Feb 2, 2014 03:34 PM
RobbyMartin
1997 - 2003 F150
Dec 25, 2009 10:15 AM
broncobasher
Nov 20, 2003 01:07 PM
shotgunner426
Oct 3, 2003 04:06 PM
