Power Window Troubleshooting
Old Apr 19, 2014 | 06:40 PM
harley3348's Avatar
harley3348
I have a 2002 F250 7.3 PSD and the drivers side power window will not go up. How do I troubleshhot it. Is it the switch, motor, fuse? The other three windows work fine.
Old Apr 19, 2014 | 09:49 PM
Franklin2's Avatar
Franklin2
Get a testlight. Take the door panel off. See if you can get to the motor wires. You need to put the alligator clip on one of the motor wires and poke the other wire with the probe and see if it lights up when you move the switch.
Old Apr 20, 2014 | 11:49 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
In most cases it is a worn out push switch. Ford keeps them in stock.
kyledallas
19
Jan 3, 2012 04:42 PM
tyler9mm
2004 - 2008 F150
Aug 1, 2007 03:11 AM
jbomb
Nov 16, 2005 03:18 AM
jcfahe01
Electrical Systems/Wiring
Jan 22, 2005 01:31 PM
mightypizu
Jan 16, 2004 03:23 PM
