Block heater
Old Jan 21, 2010 | 10:26 PM
teppler's Avatar
teppler
Block heater
Installed the cord on my block heater today .Does anyone know what the resistance of the heater should be? Mine reads 15 ohms thru the cord. If I remember my Ohms law I=E/R should yield the approx current which equates to 8 amps. seems low . Any comments?
Old Jan 21, 2010 | 11:04 PM
olfordsnstone's Avatar
olfordsnstone
I just wired in a 15 amp Marinco male outlet on the bumper of my Superduty and wired in the block heater cord. I was concerned about the 15 amp inlet being a little to light duty so I called the Ford Service Center to find out the draw on the block heaters. I can't remember exactly what the amperage was but it was only 7 or 8 amps. I think you're good to go.
I'm not an electrician so I'm not sure if I am answering your question but for what it's worth, there is my experience.
Old Jan 21, 2010 | 11:08 PM
1957F100's Avatar
1957F100
You are correct the amp draw on the block heaters in these trucks is only 7 or 8 amps.
Old Jan 21, 2010 | 11:22 PM
mohle's Avatar
mohle
Just make sure you use a decent extension cord. The longer you go, the thicker the gauge. A lot of guys also get zapped when plugging in the heater - use a GFI outlet. If it trips you've got some type of issue, be it a damaged wire to salt on the prongs.
joe f350
Dec 3, 2010 07:36 PM
drivembig
17
Jan 11, 2010 04:36 AM
WALJON
19
Dec 12, 2009 09:10 PM
zinkcalls
Dec 23, 2008 04:01 PM
jasonschwenk
Jan 24, 2006 05:34 AM
