block heater help
Old Dec 11, 2009 | 03:39 PM
WALJON's Avatar
WALJON
block heater help
Hello all the other day my block heater cord burnt up right at the block heater it was shooting sparks! it sounded like a power line arking lol
my question is does the cord screw into the heater is there a nut holding it on? also I plan on ohming the heater element itself to see if it is shot what should it ohm out at cold
thanks.
Walter
Old Dec 11, 2009 | 03:45 PM
Copedawg's Avatar
Copedawg
I don't know what the actual ohms should be and I ALSO think it should not change due to the temperature.... a domestic hot water heater filament (in your house) is about 14.? - 15?.
Old Dec 11, 2009 | 03:51 PM
Hussler's Avatar
Hussler
It's about 15 ohms.
Old Dec 11, 2009 | 03:52 PM
WALJON's Avatar
WALJON
Thanks for the reply I,m kinda hoping that it was just the cord that was dork-ed I would rather change the cord than drain the coolant to change the heater.
Old Dec 11, 2009 | 03:58 PM
Copedawg's Avatar
Copedawg
believe or not it is plugged in to the oil cooler!....I KNOW I KNOW you are thinking how can that be b/c the oil cooler is located elsewhere. But believe me, that is the oil cooler, IAW with others on the forum but apparently it is!
Old Dec 11, 2009 | 04:22 PM
WALJON's Avatar
WALJON
Thanks hussler .... cope I know it goes in the oil cooler but I thought it also heats the coolant thanks for the reply I appreciate it
Still need to know if the cord is held in with a nut or screwed in
thanks
Old Dec 11, 2009 | 05:23 PM
madpogue's Avatar
madpogue
15 ohms is aprx. right. High-school physics: V=IR and P=IV.
P=IV:
P=1000W = I*120V, so...
I = 1000W/120V, = 8.3A (aprx).
V=IR
120V=8.3A*R
R=120V/8.3A, = aprx. 15A.
Old Dec 11, 2009 | 05:48 PM
Action4478's Avatar
Action4478
thanks
Name:  block heater.jpg
IIRC it is held in by that thin clip....
Old Dec 11, 2009 | 05:53 PM
WALJON's Avatar
WALJON
Right on thanks Rick reps, and thanks to everyone else
Old Dec 11, 2009 | 05:54 PM
Copedawg's Avatar
Copedawg
I thought it was in the coolant? Is it in the oil?
Old Dec 11, 2009 | 05:57 PM
Action4478's Avatar
Action4478
Its in the coolant . Oil is near by ...
Old Dec 11, 2009 | 06:40 PM
Copedawg's Avatar
Copedawg
So it is a coolant heater, not an oil heater?
ON THAT NOTE: can we somehow MOD it to make "insta heat"?
I mean to to make soooo hot it opens the thermostat to make heat go to the coils quicker? (When plugged in overnight)
Old Dec 11, 2009 | 06:54 PM
Action4478's Avatar
Action4478
Mine already works great . I have heat right away ..Starts like summer.
Wouldn't want to warp the heads .....
Old Dec 11, 2009 | 09:02 PM
joe_13894's Avatar
joe_13894
You don't need to open the T-stat, that's just wasting heat. Mine gets probably something around 130 to 140F by touch guess. The heater is blowing warm air in maybe 10 seconds. In under a minute the cab is comfortable... even in the single digits.
Old Dec 11, 2009 | 11:02 PM
Ken_C's Avatar
Ken_C
Are they rated for continuous duty? like several days at a time? I've been leaving mine plugged in for the past few days.
