Sponsored by: Real Truck
engine block heater ohms reading
Old Dec 21, 2008 | 03:54 PM
zinkcalls's Avatar
zinkcalls
I am having trouble with the plug on the truck getting extremely hot. I am using a 12ft extension cord w/ 12ga wire. The ohms reading at the plug is 16.5 . Is this too high?
Old Dec 21, 2008 | 04:01 PM
ReAX's Avatar
ReAX
e/r=I so 110/16.5= 6.7 amps or 737 watts. That doesn't sound all that high. Perhaps the plug as some debris or trash in it creating a poor connection.
Old Dec 21, 2008 | 04:10 PM
zinkcalls's Avatar
zinkcalls
Thanks for the reply. I have looked for debris and can't find any. The plug has gotten so hot the nuetral side has become loose. I took it to the dealer. They said the cord I am using is too small. I have checked my outlet on the house and it is fine. The wire on the outlet is 12ga and so is the cord so there shouldn't be any problems there. Can't figure it out, its getting scary hot!
Old Dec 21, 2008 | 04:12 PM
ReAX's Avatar
ReAX
If it's just the plug, then something is wrong with the plug. Either corrosion on the terminals, or loose connections where the terminals meet the wires. Try another cord. The connector should stay pretty cool as long as the terminals are the appropriate size, the wire should warm if it's too small.
Old Dec 21, 2008 | 04:19 PM
counciller's Avatar
counciller
i would think its a bad extension cord - just try another one
Old Dec 21, 2008 | 04:20 PM
zinkcalls's Avatar
zinkcalls
Do you mean try a new plug on the truck or try a new extension cord? Thanks
Old Dec 21, 2008 | 04:27 PM
counciller's Avatar
counciller
is it the cord on the truck getting hot or the extension. if its on the truck - its probably wire strands broken in the molded plug and it would need to be replaced
Old Dec 21, 2008 | 04:35 PM
zinkcalls's Avatar
zinkcalls
Its the plug on the truck. I am using a brand new extension cord. Took the truck to the dealer, they told me everything on the truck was fine but the loose prong on the neutral side concerns me. I should take the truck and the cord I use to the dealer and have them look again I guess. Thanks for the help. This is a great site!!
Old Dec 21, 2008 | 04:39 PM
counciller's Avatar
counciller
ill bet its loose or broken strands inside the molded plug - you need to have it cut off and replaced or a new cord installed.gotta keep in mind all the "wiggling" you do when you plug and unplug the heater - it will break strands when done often enough.
Old Dec 21, 2008 | 04:43 PM
KelVarnson's Avatar
KelVarnson
I recommend replacing the plug on the truck with a heavy-duty one. You could use a Marinco marine plug, like some people here (myself included) have done, or you could just get a heavy-duty plug from the hardware store. Keep in mind weatherproofing.
A loose connection in this area is not to be trifled with. High resistance at the plug will cause more power to be dissipated there, which of course means more heat. Tight, clean connections are necessary.
If you decide to replace the plug, keep the old one around verify the locations of the connections when you install the new one.
Old Dec 21, 2008 | 04:58 PM
zinkcalls's Avatar
zinkcalls
Do you mount the Marinco plug to the bumper?
Old Dec 21, 2008 | 05:17 PM
zinkcalls's Avatar
zinkcalls
Thats a dumb ? after looking at the plugs design. My truck is still under warranty so if Ford gives me a new plug I will stick with that for a while. But I sure like the Marinco plug idea.
Old Dec 22, 2008 | 12:38 AM
KelVarnson's Avatar
KelVarnson
There are people who have mounted it to the bumper, and other places. Do a search on "marinco" on this site, and you'll find lots of info.
Old Dec 22, 2008 | 11:13 AM
mwsF250's Avatar
mwsF250
I'm with all those pointing at the plug on the truck.
Heat occurs when electrical current encounters resistance. Your symptoms all point at the neutral contact on the truck plug.
It is unfortunate the "mechanics" at that dealership do not understand the basics of electricity. Time to move on to someone who knows what they are doing.
Old Dec 22, 2008 | 11:22 AM
ReAX's Avatar
ReAX
Why at the neutral? Resistance to the return path from the hot path should create heat as well? Heat is a byproduct of amperage backing up. If the resistance is high before or after the heating element, then the total resistance is higher, but the point where the resistance is highest should be hottest, correct? I guess I am trying to say that in series does it really matter where the resistance is in this case?
