water separator drain plug
Old Jan 21, 2010 | 05:28 PM
raptor2005's Avatar
raptor2005
hello eveyone i just tried to drain the water for the first time in my 2005 2wd 6.0 diesel and notice the plug was strip i found the replacement plug online thanks to the tech folder . i was just wondering if any one had this problem and can tell me the best way to remove the strip plug.
thanks for all the help
Old Jan 21, 2010 | 05:30 PM
utjer's Avatar
utjer
Some people are using a hex wrench and jb weld to glue it on to get it out of there.
Old Jan 21, 2010 | 07:22 PM
rthacker's Avatar
rthacker
Had the same problem. The bolt is probably not stripped , but has corroded from the inside missing up the threads on the bolt not the threads on the manifold. I unbolted the four bolts on the manifold and pushed it out from the inside. Go to Ford and order the new bolt which is brass and is a blue diamond part #.
Old Jan 21, 2010 | 07:42 PM
Superdutyintendent's Avatar
Superdutyintendent
try this once you get it out....
HFCM Drain Plug
lots of info through the search feature here on how to get a stuck plug out ie JB weld, screw extractor slot the plug...
Old Jan 21, 2010 | 11:48 PM
raptor2005's Avatar
raptor2005
thanks superdutyintendent i saw those went to the part store looks like i will have to order it online. utjer i would have never thought of that thanks.
Old Jan 22, 2010 | 07:44 AM
texans's Avatar
texans
I bleave you can get it at the international dealer, if you have one near you. I dont know the part number though.
Old Jan 22, 2010 | 06:09 PM
jamie7375's Avatar
jamie7375
Did u get the old plug out? I have the international part# if u need it..
Old Jan 25, 2010 | 04:36 PM
raptor2005's Avatar
raptor2005
jamie7375 i would love to get that part number working long hours dont have time to work on it and ford told me today they cant order the replacement just the OEM
thanks for the help
Old Jan 25, 2010 | 04:39 PM
raptor2005's Avatar
raptor2005
no i eant to wait till i get the replacement part to remove it to scared to leave it open to the elements dont need any new problem thanks for all the help.
al0311
Jan 16, 2016 12:43 PM
MS86
May 22, 2015 02:00 PM
rattleNsmoke
Oct 29, 2012 11:28 AM
schmitty99
May 8, 2011 09:17 PM
RickBraden
Oct 6, 2010 06:54 PM
