6.8L Oil Drain Plug Torque Spec
2005 6.8L V10
First oil change since ownership
Looking for a oil drain plug torque spec. I searched and most every response was "Install a fumoto drain valve" or "Probably like 25-30 ft. lbs."
Need actual question answered please - have had bad luck in the past with stripped oil pans...if you are wondering why I'd torque the oil drain.
I highly doubt it's anywhere near 25-30 ft. lb.....
Also, do these motors use oil drain plug seals/gasket, or is it built into the plug.
Thanks
Mike
Thanks
Mike
My 01 mustang Cobra drain plug torque spec, is 14 foot pounds.
I use the same for my 6.8 V10.
Yes there is a gasket, white plastic , for the drain plug.
I have not had to replace it since I bought my truck 2 years ago.
I have 40.000 miles on it since purchase, and change the oil every 4k miles or so.
All of my miles are on the hiway and are at minimum an hour and a half each way.
