timing bracket missing!
Old Jan 20, 2010 | 09:55 PM
mike L's Avatar
mike L
Where does the timing bracket connect to? The garage said they could not time the engine, because the bracket is missing. Do you time the engine from the passange side of the engine?
Thanks guys
93 f10 5.0
Old Jan 21, 2010 | 06:59 AM
subford's Avatar
subford
I stand in front but to the passenger side to time it.
Old Jan 21, 2010 | 01:59 PM
mike L's Avatar
mike L
Thanks! I found it, it's loaded with oil and dirt. On the piture you provided are there lines on the pointer, to time the engine?
Old Jan 21, 2010 | 02:03 PM
lew52's Avatar
lew52
The timing marks are on the balencer , clean it off good & highlight them so you can see them , don't forget to remove the spout ...Lew
Old Jan 21, 2010 | 02:59 PM
subford's Avatar
subford
Here is an image:
Old Jan 21, 2010 | 04:15 PM
mike L's Avatar
mike L
On the timing bracket its self do you use the very end of the bracket or is there a mark on the bracket pointer?
thanks
mike
Old Jan 21, 2010 | 04:22 PM
subford's Avatar
subford
thanks
mike
Just like the diagram above that is pointing at 10 BTDC.
Old Jan 21, 2010 | 04:29 PM
mprice's Avatar
mprice
Everyone has their own tricks for making the timing marks stand out on the balancer. I've found that after a couple of passes with fine sandpaper it helps a lot to rub anti-seize on the marks and then lightly wipe it off with a rag. The silver stays in the grooves of the marks and really lights up in the timing strobe.
52 USCG Panel
Mar 22, 2017 03:09 PM
1954Bob
Dec 3, 2016 03:59 AM
teamo
Sep 26, 2016 11:45 AM
Motoxman_117
Sep 17, 2016 12:06 AM
KCampbellNH
Jan 20, 2015 02:13 PM
