Sponsored by: Real Truck
2001 fog light mod
Old Jan 19, 2010 | 06:41 PM
reddogracing's Avatar
reddogracing
2001 fog light mod
Ok i have read tons of info on this mod. My concern at this point is just the '01. From what I gather, you can pull the headlight switch, cut the red/yellow wire, and tap it into the brown wire.
My question,
Can you still turn the fog lights off with the existing push pull switch, or will this make them run whenever the headlights are on?
I am good with schematics, but haynes manual is not great for the F series. It is better for the excursion, but it looks to me like this might make the fogs on any time the headlights are on.
Some ppl might not want that. Like myself.
However if that is how it turns out, I have anouther idea.
I just had an idea, tell me what you think.
http://www.dfuser.com/catalog/harness.php
https://www.ford-trucks.com/forums/9...as-how-to.html
For the headight wire upgrade, you only need to use one side of the existing headlight plugs.
Our fog lights use a headlight bulb. Most ppl upgrade these.
So why not upgrade them to high low bulbs. Make anouther headlight upgrade harness, or buy one, without the high/low mod. Use the other existing headlight wire to trigger the second harness, and hook the second harness to the fog lights. Then you do not have to worry about modding the switch or wires, and you end up with high and low fog lights.
would that work?
If the push/pull switch does still work, you could add anouther relay, on the hot wire from batt, and still shut them off if you like. But like i said if the current mod leaves them on with the headlights, you could do this and get the same effect, with less hassle, and better voltage to the lights.
Old Jan 20, 2010 | 06:36 PM
Johnny Bravo 45's Avatar
Johnny Bravo 45
not sure what your looking for but this link show ya how to hook up your fog light so they stay on with or without hi beams and you can turn yoru fog lights off with the light switch.
https://www.ford-trucks.com/forums/5...info-here.html
Old Jan 20, 2010 | 07:50 PM
reddogracing
Thats is one mod, but i read where the fuse box mod does not work on th 2001 f series. Reading through all those pages now to see if it is mentioned there. Actually the mod i speak of is on page 7.
There is a mod for the 01 where you do the same type thing, but you do it behind the headlight switch.
I think I will get 2 of the harness i posted, 60$ for upgrade harness and relays, which i will use for fog lights. hooked to right headlight
80$ for harness with mod to run low beams with highbeams. hooked to left headlight
http://i.b5z.net/i/u/1632828/i/Upgra...rness_INST.pdf
and i think i will go ahead and put high/low bulbs in my fog lights as well.
Should be like having 4 low beams on low, and 4highs 2 lows on high. A lot of light I think.
Old Sep 4, 2012 | 11:30 PM
yukonjack0313's Avatar
yukonjack0313
2001 ford 350 superduty...I wanted to run a separte toggle stwitch for my fog lights ..I tapped into the brown and black by the front fender and ran them to the swtich...but no lights ...is there a sercet...Thanks Brad
Old Sep 5, 2012 | 12:55 AM
Yahiko's Avatar
Yahiko
Reddogracing
Looks like an OH-58 Kiowa
Sean
Old Sep 5, 2012 | 10:30 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
2001 Fog Lamp High/Low Mod
In 2001 I wired my fog lights to stay on with the high/low beams. It is taped into the loom and I cannot see the connections, I will try to get a look at it and post it.
Old Sep 5, 2012 | 01:27 PM
Yahiko's Avatar
Yahiko
go here and look in the tech folder
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You are looking for the fog light mod should be close to the
same as the 6.0L or you can get an idea on what Ford was doing.
Sean
Old Sep 5, 2012 | 07:11 PM
reddogracing
I pulled the headlight switch.
took about a 4 inch wire and stripped each end 1/4 inch
shobed one end in with the brown wire, and the other in with the red/black wire,
now running lights are on whenever any others lights are one parking low or high
this is a quick and easy way to do it without and mods, and you can remove it quickly if you find out that you dont like it.
Old Jul 16, 2025 | 10:17 PM
Mudslinger021485's Avatar
Mudslinger021485
2nd Gear
Any chance you could provide a picture of the terminal location? I have a 2001 Canadian DRL model. I Disabled the DRL switch a few years ago. I Modified the headlight switch to put out with the park lights on but the fogs still won't turn on unless the headlights are on.
robinsonpowerstroke
6.7L Power Stroke Diesel
39
Nov 13, 2019 06:58 AM
onephinesuperduty
Nov 24, 2009 02:19 PM
kernman
Apr 20, 2007 11:13 AM
Aaaaaron090
Jan 3, 2007 01:22 PM
4X4 IN REFUGIO
Oct 11, 2005 12:31 PM
