Fuel dumping from overflow? under truck
Old Jan 13, 2010 | 10:04 AM
drivembig's Avatar
drivembig
Hi, I have a friend that isn't online and has seen what a great you guys have been for me on here and wanted me to post a question for him.
He has a 1999 Ford F-350 dually 2wd crew cab with a 7.3L turbo diesel.
When he starts the truck, about a gallon or so of fuel dumps onto the ground under his truck up towards the front.
When we looked under it it is coming out of a line that just hangs down, like maybe a filter bowl drain and some sort of drain line.
Has anyone had any experience with this? I'm at work now, but will check to see if maybe the fuel filter bowl drain is open or not, but it only does it when he first starts the truck up. After that it is fine.
Thanks for any help on this.
Old Jan 13, 2010 | 10:34 AM
just another truck's Avatar
just another truck
It is the fuel bowl drain line, it has a yello handle and it is on the back of the fuel filter, turn that 90* and your leak should go away..That is what is hooked up to the hose you are describing, I just cant answer why it would stop leaking.
Old Jan 13, 2010 | 10:40 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Like Pat said, I don't understand why it quits after leaking that much fuel. Here is the way to fix your leak. LINK
Old Jan 13, 2010 | 10:53 AM
drivembig's Avatar
drivembig
Thanks for the quick replies. I figured it would be the drain valve. As for the reason why it stops don't know either. Maybe the sudden burst of pressure is just letting it blow by the Orings and then it will seal back as pressure equalizes....don't know. Either way, we will follow the link above and rebuild it. Thanks.
Old Jan 13, 2010 | 11:02 AM
Izzy351's Avatar
Izzy351
I have this job to do now. When I was in Austin I could smell a little fuel, and sure enough, it's coming from the drain valve. I guess I'll call Bob...
Old Jan 13, 2010 | 11:13 AM
Pocket's Avatar
Pocket
Sounds like bad drain valve o-rings to me too.
Old Jan 13, 2010 | 11:16 AM
miller_feed
Be sure to put a white rag under the valve. You will be happy you did to catch the little screws when they fall. I was glad I did.
Old Jan 13, 2010 | 11:46 AM
just another truck
I prefer the MF method
Mother f(*&*&( where them screws go....
Old Jan 13, 2010 | 11:54 AM
HH60FE's Avatar
HH60FE
Yep, I chased one screw up under the HPOP so far I had to dislocate my fingers to retrieve it. Shoulda used the rag method.
Old Jan 13, 2010 | 01:56 PM
BillyBob69's Avatar
BillyBob69
Ugh... man I swear this happens all the time.... You guys are all wrong...It's the drain valve. Sheesh!
(The MF method is my favorite too.)
Old Jan 13, 2010 | 02:31 PM
brian42's Avatar
brian42
Veteran: Navy
Even when I used the rag method, I ended up using the MF method trying to start the screws blindly in the holes for the bottom two. The engineers obviously did not consider this a "routine" evolution! IIRC the screws are a Torx T-20 and there are 4 of them. Don't overtighten them or you won't be able to operate the valve!
Old Jan 13, 2010 | 05:54 PM
Bigcat350's Avatar
Bigcat350
I used the rag method and it helps but the best tool was my extendable magnet.
chunt
24
Apr 25, 2016 08:11 AM
bike_guy123
28
Sep 3, 2014 09:12 PM
NS F250
35
Feb 4, 2014 08:50 PM
CatchersDad97
57
Jun 7, 2013 03:17 PM
slpj
Jul 8, 2007 05:22 PM
