starting problems
Old Jan 11, 2010 | 07:54 PM
ddiskin41's Avatar
ddiskin41
starting problems
ive been having problems starting my 86 f350 i know that it has been cold at my house at night (subzero at nights) but ive had to charge the battery to start it the other day. and today it was rough starting. any suggestions?
Old Jan 11, 2010 | 07:57 PM
starmilt's Avatar
starmilt
We need a definition of rough.
Old Jan 11, 2010 | 07:58 PM
johnboggs21's Avatar
johnboggs21
I suggest pluggin in the Block heater when it gets that cold if its an option.
Old Jan 11, 2010 | 07:59 PM
ddiskin41's Avatar
ddiskin41
it would crank for a minute then have like a low rumble then come to life and the other day i had it plugged in over night and we had to charge the battery but once we did that it started rite up cld it be a low battery
Old Jan 11, 2010 | 08:36 PM
WarOzz's Avatar
WarOzz
First thing I would do is have the batteries checked and load tested. Eliminate the easy before troubleshooting the more difficult stuff.
Old Jan 11, 2010 | 10:46 PM
PLC7.3's Avatar
PLC7.3
I notice you say BATTERY as in one....... you need 2, minimum CCA 850 each new in pairs when replaced.
wreckinball's Avatar
wreckinball
yeah start small, load tests can usually be free, you can test GP's free etc etc. Even a brand new F350 is supposed to be plugged in at anything under -5 to -10 F. Dont think it is bullet proof when it comes to those conditions, give it a break and plug it in if you can. Mine will snap to life within a revolution at anything above 16 F but that is all i have been able to test. I still plugged it in on a timer to warm 2 hours prior to my departure. that is cheaper than a starter or batts in my book.
Old Jan 11, 2010 | 10:53 PM
rupejosh's Avatar
rupejosh
how many cold cranking amps are the batteries rated for?you need atleast 850cca per battery for cold weather.with hard starting you can have glowplug ,battery,starter,return line,fuel line,or electrical connection issues
kdaug5
May 7, 2014 07:05 PM
Iaff113
Jan 17, 2013 06:17 PM
muddywater
Jan 24, 2012 06:45 AM
sju96ford
Jul 21, 2011 10:51 PM
beefmalone
Jan 9, 2011 02:41 PM
