460 distributor probelms?????
Old Jan 9, 2010 | 06:26 PM
kona56's Avatar
kona56
i have a 86 f-250 with a 460 it starts up and immediatly dies.change the ignition module twice and checked coil??? havent tryed a distributor yet ??
Old Jan 9, 2010 | 06:31 PM
Franklin2's Avatar
Franklin2
Pull the aircleaner off when it won't run, and look down the carb throat while pushing back on the throttle. You should see fuel squirting down into the engine. If not, then you are running out of fuel.
A lot of the 460's had electric fuel pumps in the tanks with a fuel pump relay up front, and a oil pressure switch that controlled the relay. The relay was bypassed when starting, but power to the fuel pumps came from the relay and the oil pressure switch after the engine starts. People have a lot of problems with this system.
olyellow
Jun 23, 2013 09:51 PM
ClatonK
Oct 16, 2005 06:47 PM
nevereverquit
Dec 29, 2003 06:59 PM
topmoo
Nov 16, 2003 09:06 AM
georgedavila
Jun 20, 2002 08:53 AM
