HEI distributor for Ford?
Old Nov 15, 2003 | 10:13 PM
topmoo's Avatar
topmoo
Anyone know who makes an HEI distributor for a '75 Ford 460?
Old Nov 15, 2003 | 11:01 PM
BigBully's Avatar
BigBully
Im pretty sure its DUI that makes one for the 460. look in a 4x4 magazine and im pretty sure you will find one
Old Nov 15, 2003 | 11:10 PM
Matts72's Avatar
Matts72
Accel, MSD, Mallory.
You can upgrade your ignition box, to a Capacitive Discharge unit or a multipe spark unit that will improve the throttle response and will help even out you idle. You might get better fuel mileage.
Crane Cams Hi - 6 makes an excellent box, I have them on a pair of 390's in 68 and 71 F100's, both motors get 14-15 MPG.
Old Nov 16, 2003 | 09:06 AM
FordBoypete's Avatar
FordBoypete
Wink Henry makes his own breakerless system
FoMoCo makes OEM breakerless system for their 460s in Trucks from 77 up, w/ 460 CID. Usually they have Blue band/ Blue struck System. Lincolns also use same, Blue Band system thru 78, then in 400s after 79, which also fits. A 351M/400 system works, but you may want to tune advance curve to reflect 460s needs better.
I can't twist my 460 RPM up high enough to scramble signal or function of OEM Blue Band system. I can also run a standard, non electronic ignition, 1 piece, distribuitur cap, using a set Magnetic Supression Wires on OEM distribuitor base, instead of the Stock 2 piece cap & fat wires. . . . .
But then again, I can only seem to get my truck into mid 12s in the 1/4 mile with trap speeds avg of 125+mph. So maybe I'm not running hard enough to know the difference????.
FBp
bigfoot7180
Aug 12, 2011 03:15 AM
windsor4x4
Aftermarket Products
Jan 19, 2008 06:29 PM
black58
Mar 31, 2006 02:23 PM
68Eric
Oct 8, 2005 08:33 PM
