Okay, now I'm worried - spark plugs issues
While looking for ways to improve the gas mileage on my "new" 2001 (lost my '94 and a small part of my heart in a recent flood saving my mother-in-law's property), I stumbled across a series of articles and consumer complaints about spark plugs blowing out of these Tritons. I'm actually worried about getting in my new truck and driving it. Sort of took the wind right out my sails of excitement over owning a new truck.
I guess my questions are, how worried should I be? Does blowing a plug actually strip the aluminum threads right out of the heads? Does it happen often enough that I should expect it to happen? Or, should I just drive it like I stole it and enjoy it until the inevitable occurs?
Thanks.
Thanks.
Thanks.
Thanks.
Actually, spark plugs have and continue to blow (explode) out of the aluminum heads even when the plugs were installed new at the Ford factory. Additionally, inserts are prone to blowing (exploding) out the aluminum head too. Go to YouTube and search "FORD TRITON BLOWN SPARK PLUGS" and see a video of a Triton having blown it's second plug (an insert that didn't hold) and also "Google" a search for blown plugs (or ejected plugs) Ford Triton.
On one ocassion, a Ford Triton caught on fire when the spark plug blew out of the aluminum head, ruptured a fuel rail just above it (the plug was still sparking at the time of the ejection) and the truck was completely lost in the resulting fire. This particular event occurred in a F150 truck, having the original factory installed spark plugs.
Some evidence also suggests that the failure rate is more excessive at spark plugs located on the rear of the engine and problematic on the right rear passenger side. Some speculation also reveals that the ejection rate is higher during warm summer seasons than during winter.
Possibly, adding a ram air duct from the front of the vehicle to the rear of the engine (in the area of the rear spark plugs) may help address this issue, but this seems to be a band-aid approach to a faulty designed aluminum head, allowing only 4 threads to hold the spark plug inside the spark plug boss.
<!-- google_ad_section_end -->
I KNOW THAT THIS IS NOT MY WORDS, BUT I FOUND THIS AND JUST COPIED AND PASTED. ENJOY.
Just like every other Manufacturer has there issues with engines, Yes, this can happen on the Triton modulars, I personally haven't expierienced it(yet) on my 01. I have 102k on the original plugs and I check the torque on them every 7500 miles or so. One thing to do is to listen for any changes or odd noises, like popping or clicking while running, this is a telltale sign of an issue up and coming! For as many post you read on here about blowing plugs, there is millions of Triton motors out there that do not have the issue.
Just my 2 cents
Rich
Just my 2 cents
Rich
it can happen, but not that common. also it normally happens after the plugs have been replaced, and probably overtorqued and pulled the threads. No that it NEVER happened on factory plugs, but i think most of the time it was after replacement. I have changed mine, i think thats a good idea... you just got to remoeber to torque right, not over torque and pull the threads.
I read all the threads about the problems with the plugs. I was getting to 10 years and 94K on the original plugs and worrying about corrosion. With new plugs, I did all the work myself and did it albeit slow about 5 hours.
It would be easier if you have a good selection of tools to remove the bolt for the Coil on Top of the plug. I think is was an oddball size of 5/64. I finally remembered I had a small nut driver in my electrical tool set. It made it a lot easier. I did one plug at a time to avoid mixup of wires. I did not remove the fuel rails.
Need a good selection of extensions, and universal joints.
I ran the engine for about 3 minutes to get the engine warm so the head were not cold. Since it took so long for me, I rand the engine 3 more minutes after 2 hours. I used antiseize on the threads of the sparkplugs. Use a torque wrench on the plugs for sure.
There is a video of two guys doing the job somewhere on the internet with about the same year--- no url saved.
That's what you should torque dry plugs to (12-14 lb.-ft.), when you add anti-seize to the spark plug threads you should only torque them to 10 - 11 foot pounds.
Thanks guys - y'all are the best. I got the response I was hoping for and then some. I'm gonna have fun with my new truck
I really appreciate the input on changing these plugs. I've always done the work myself, but never paid much attention to the torque of the install. Will certainly do that this time because I'm due new plugs/wires.
Is there a trick to getting them out without breakage?
Thanks again fellas - you've made my day.
OneMeanZ
1999 to 2016 Super Duty
11-16-2015 09:08 AM
mdh1701
05-06-2014 12:27 AM
shanksyamaha
Modular V10 (6.8l)
23
03-17-2011 09:14 PM
