PCM Reflash ?
Old Jan 6, 2010 | 09:17 PM
fordpride's Avatar
fordpride
PCM Reflash ?
I think i may need to reflash my truck. what would be the reasons for someone to do this i have a superchips pro. i know i know it was a wast of $ but i think it may have messed my PCM up what do you all think
Old Jan 7, 2010 | 04:24 AM
drivembig's Avatar
drivembig
What kind of problems are you having to believe that you need a reflash?
Old Jan 7, 2010 | 05:59 PM
fordpride's Avatar
fordpride
shifting funny never the same way twice,giving it the go pedal someetimes it will fall flat on it's face or get up and hall **s,GP'S fire some times(new GPR),to me the truck does nt run as smooth or as hard as it use to
Old Jan 7, 2010 | 06:09 PM
c00nhunterjoe's Avatar
c00nhunterjoe
you can just remove the chip, that puts the stock program back in. i cant see the program causing intermittant problems liek that. plus the chip does not change glow plug control.
at 172k are your injector o-rings origonal? could be leaky causing the performance issues with the chip on top of a 14.7k.
remove the chip and the 14.7k and see how the throttle response is. let it warm up and then hold the pedal on the floor, see what the truck does. if all is well the truck will rev right to the limiter fast and smooth. if it is leaky then it wil stutter and stumble and have smoke from the exhaust
Old Jan 7, 2010 | 07:21 PM
fordpride's Avatar
fordpride
okay put back to stock and removed 14.7k held pedal to floor RPM went to 2500then struggled a bref sec. then jump to 3000 RPM should it do that or shuold it go all the way to redline. does this sound like a fuel problem
Old Jan 7, 2010 | 07:48 PM
c00nhunterjoe
injector o-rings are leaking. it should go to the redline fast and smooth, the struggling from 2500-3000 is the leaking o-rings.
Old Jan 7, 2010 | 07:53 PM
fordpride's Avatar
fordpride
my hpop has a small leak if that matters.also i started the truck and unpluged the ICP and it stummbledjust a sec. then ran like it was still plug in should there be a bigger dif.
Old Jan 7, 2010 | 07:55 PM
c00nhunterjoe
is the pump leaking or just the resevoir? i doubt that is the problem. the icp test you did is normal, no problems there either. in my opinion the stumble is caused by the o-rings
Old Jan 7, 2010 | 08:00 PM
fordpride's Avatar
fordpride
o-ring on big plug on the pass. side top under wireing harnness.wheres a good place to get injector o-rings and will it hurt anything to drive it like this if i put it off till this spring. i hate on this truck when it's cold LOL!
terrymargate
Mar 26, 2016 07:03 PM
emery72
Mar 16, 2012 11:18 AM
FordProTrucks
Alternative Fuels, Hybrids & Mileage
Jan 12, 2012 04:52 PM
AndeyHall
Jun 7, 2011 04:04 PM
redman84
Mar 8, 2011 11:28 AM
