Get a flashlight and a small mirror on a stick You know the ones you get from the parts store.
Now shine the light under the hood down at the PCM. On the drivers side of the plug as it goes thru the firewayy you will see the number. You need the mirror to see it from this point of view.
Otherwise you can remove the PCM and get it when you get it off.
