looking for fuel lines
Old Jan 3, 2010 | 04:35 PM
pabs's Avatar
pabs
I have a 91f250 non turbo ive been havin starting issues and relized i have some leaks in fuel lines near tank.Also cant seem to stop leak at one injector replaced o rings twice and any info about injector leak,can they leak internaly?So if anybody knows were to get fuel line from i could use the info.Thanks for your help and its good to be back.Good to see all you guys are still here.
Thanks for your help.
Old Jan 3, 2010 | 04:50 PM
wminmi's Avatar
wminmi
New to the ford diesel trucks, so bare with me....
Cannot help with the leaking o-ring issues, again bare with me....
On my '89 Cummins powered dodge I had a fuel line break, I went to Auto-Zone and got all new lines for it for pretty cheap. Granted, they were'nt pre-bent or anything and I did have to cut some down to size, but they worked like a charm once I figured out what sizes (diameter) I needed. Been 4 years with them now and no problems what-so-ever.
Other than that, LMC truck (www.lmctruck.com) shows complete brake line kits and fuel line kits.
Hope this helps some.
Old Jan 3, 2010 | 11:41 PM
rupejosh's Avatar
rupejosh
the o-rings are not the problem its probably the return line cap being warped and not sealing on the o-rings and injector.where is it leaking from the top or bottom?
Old Jan 3, 2010 | 11:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Leaks in the fuel lines between the tank selector valve and the tanks is not a common problem.
Those nylon lines are rather tough.
The couplers do have an O ring in them, but unless you have had the lines off and back on, again not a common problem.
The metal lines that come up out of the fuel tank and hooks to the lines, that is a problem area.
Dirt and saly just lays there, and washing it out is not really an option with the stock bed mounted.
If you want to replace them anyway, 3/8" fuel line for the supply line and 5/16" fuel line for the return line and attach them to the fittings with hose clamps.
Any place the line may rub on something, 1/2" heater hose makes an excellent bushing to protect the fuel lines.
From the tank selector valve forward the lines are metal, and several people have had problems with rust under the frame clips causing leaks.
Old Jan 3, 2010 | 11:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
uh oh.
say some fool replaced the lines,and used 5/16 for delivery too.what's going to happen to this fools truck lol.
is it going to starve for fuel under a load?
(man,i could have swore it all looked like the same size.oops.)
Old Jan 4, 2010 | 12:17 PM
pabs's Avatar
pabs
it seems to be leaking from the top.
Old Jan 4, 2010 | 12:19 PM
pabs's Avatar
pabs
it looks like its leaking from the top.Is there a fuel line repair kit avalible for these trucks?
Old Jan 4, 2010 | 12:27 PM
Smokedagin's Avatar
Smokedagin
I just got back from my local Ford dealer and they had all the parts I needed to fix the fuel lines. One of the return fittings was $5.
Everyone recommends changing all the return lines and fittings. Probably good advice. I'm going to just try fixing one and see how it goes.
If I had followed all the good advice I've been given over the years, I could go buy a dozen new trucks and wouldn't have to fix this one!
Old Jan 4, 2010 | 01:34 PM
Coolball's Avatar
Coolball
Oh they do! That could explain....lol...didn't even notice but since the replacement I noticed the frame around the select valve wet. Good bit of info right there!
Old Jan 4, 2010 | 01:35 PM
FORDF250HDXLT
6.9 6.9L 7.3 7.3L Ford Injector Return Line Kit 89 - 94:eBay Motors (item 200421454522 end time Jan-07-10 23:59:00 PST)
OR
6.9 6.9L 7.3 7.3L Ford Injector Return Line Kit 83 - 88:eBay Motors (item 170424041422 end time Jan-07-10 23:59:00 PST)
AND (optional.but worth it.)
use Viton O rings bought separately,and say goodbye to leaks from those standard O rings.
Replacement O-rings for Ford Diesel Engines
Old Jan 4, 2010 | 07:08 PM
FORDF250HDXLT
i hope Dave see's the mistake i made in post #5 above.
anyone else know if this will be a problem or not?
Old Jan 4, 2010 | 07:25 PM
9473's Avatar
9473
Originally Posted by FORDF250HDXLT
uh oh.
Mine has 5/16" for both.
Old Jan 4, 2010 | 07:52 PM
starmilt's Avatar
starmilt
Give it a month and post back how it's working please.
Old Jan 4, 2010 | 08:51 PM
FORDF250HDXLT
oh good.i could have swore mine was too.thanks.
it must be diff for our 9th generations then.
i saw the tank clips where larger and smaller for the stock FSV,but the lines looked the same(edit:yeah,i know they are,cus i slid the hose on each and it fit the same going into/out of the tanks).i knew i couldn't go by the new FSV cus its just a universal anyway.(the 5/16 lines slid on np with some Vaseline on the return fittings.)
pawayne63
Nov 8, 2016 07:31 PM
KEB59
Feb 19, 2015 04:10 PM
hardwaterfreak
Nov 16, 2011 01:06 PM
uchitz
May 16, 2008 05:48 AM
chipper
Oct 20, 2006 02:03 PM
