1987 cold and hot start problems resolved
Old May 15, 2008 | 05:57 AM
uchitz's Avatar
uchitz
Thumbs up 1987 cold and hot start problems resolved
Just to let you folks know, at long last, I solved the problem. After having changed all rubber hoses, including the dropping and checking both fuel tanks, change of injectors, lift pump, injection pump, injector return lines and plastic fittings, I still had this staring problem. I played around with clear plastic hoses, measured fuel flow and pressure at the schrader valve near the filter, measured compression of the cylinders, changed a starter, because the old one got worn out. Long last, a simple clear fuel hose as the return line from the filter to the injector fuel return gave me an indication where the air entered the system.
The connection fitting of the fuel supply to the IP was not tight enough and LEAKED FUEL. The amount of fuel was small enough, that one could not see it trip from the truck, but air raising up the the filter/plastic line gave me the hint, where to look.
This was a real boner and that's why I thought I share this info. with the forum.
Thanks to all for your help and suggestions.
Old May 15, 2008 | 06:53 AM
Lazy K's Avatar
Lazy K
Good man. Nice to here back when someone gets a fix.
Old May 16, 2008 | 05:48 AM
Dieselamour's Avatar
Dieselamour
Thanks for the info also.
aboisseau
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 15, 2013 12:20 AM
Coccyx
27
Jul 6, 2013 06:57 PM
gummybear918714
19
May 29, 2011 02:56 PM
HD Rider
Apr 9, 2010 06:53 AM
mikerons
Mar 2, 2007 08:07 AM
