ccv mod ??
Old Jan 4, 2010 | 12:32 PM
CAMPINGTOM's Avatar
CAMPINGTOM
Originally Posted by bismic
The maximum pressure spec on the crankcase is 0.3 psig.
I personally wanted the suction effect of the intake.
Quite a few others do not feel it is needed.
Either way, if you run hose for a very long distance, use 1 inch hose.
So, Mark, you are saying that there may not be enough pressure in the crank case and that's why you wanted the suction to "suck" it out?
I guess that's my concern too.
I think I read somewhere that on the IH version of this engine (VT365), they just vent to the atmosphere.
Old Jan 4, 2010 | 03:47 PM
bismic's Avatar
bismic
As Tim said, you should very well be able to vent to the atmosphere. If you do, use a large enough hose to avoid back-pressuring the crankcase.
You really want to keep the crankcase pressure as low as possible.
Old Jan 4, 2010 | 04:24 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Yeah, but more importantly I said I did it that way because I was too lazy to do it how you did yours!Seriously, alot of machinery I have run has CCV vent to atmosphere, well, the older stuff anyway. I'm sure the Tier 3 stuff which is the newest emission standards for heavy equiptment has it doing something other than vent to atmosphere. Probably back into the intake, but not sure.
Old Jan 4, 2010 | 04:56 PM
dvldog458's Avatar
dvldog458
When using the 1" hose...will regular heater hose work? Or should I be looking at some sort of Hi temp exhaust hose?
Old Jan 4, 2010 | 05:09 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I just used the black heater hose, or whatever its for, from Lowes. You don't need hi-temp just ziptie it away from the manifold.
Old Jan 4, 2010 | 05:15 PM
gearloose1's Avatar
gearloose1
The issue is the hose should not be kinked or have a dead J leg where water and oil vapors can accumulate and block it.
Heater hose will work, so will any other hose that does not collapse easily and can withstand extremes of heat and cold a part on the outside of a truck is normally subject to.
My only reservation with the 1" hose out the back of the truck is that it might get plugged with ice / frozen crud, or from mud / water if the truck is used to ford streams.
Old Jan 7, 2010 | 04:56 PM
dvldog458's Avatar
dvldog458
What do you guys think of these two breather tanks for use at the end of the 1" hose?
http://www.summitracing.com/parts/MOR-85465/
http://www.summitracing.com/parts/JZP-605-225-01/
Old Jan 7, 2010 | 06:49 PM
rocky1074's Avatar
rocky1074
I think they look real cool. Not sure how they will work but can's see why not.. Guess well have to get some input from the pros...
Old Jan 8, 2010 | 06:50 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Someone had done one with a filter/canister from TSC, maybe like this Fuel Filter, 1 in NPT Female - 3958244 | Tractor Supply Company Maybe not exactly this, but IIRC it wasn't all that much money.
Old Jan 8, 2010 | 10:21 AM
rocky1074's Avatar
rocky1074
I think this is the one that I've seen someone use from tractor supply:
Polypropylene Strainer, 1 in. dia., 50M - 2114130 | Tractor Supply Company
Old Jan 8, 2010 | 10:45 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Yep, that appears to be the one. I searched and couldn't find it, I knew it looked similar to what I linked. Thanks, Rocky! And only $20 too!
Old Jan 9, 2010 | 05:45 PM
dvldog458's Avatar
dvldog458
I wonder with extra boost that I'm putting out ...while I need a better CCV evac system.
2011F-250KR
6.7L Power Stroke Diesel
Feb 25, 2015 10:13 PM
Tact
Nov 19, 2013 07:50 PM
Robert6401
Dec 10, 2012 08:24 AM
98SurplusExpy
Mar 11, 2010 10:02 AM
zsir
Apr 19, 2003 01:07 PM
