ccv mod ??
Old Dec 30, 2009 | 10:53 PM
ConvertedFord's Avatar
ConvertedFord
ccv mod ??
Finally did it but the o-ring on the 90 elbow was completely destroyed. I didn't replace simply because I didn't have one on hand. Will it cause any problems? I simply ran 1" ID hose to the back of the fuel tank and capped off with a 1" PVC plug. Looking for filter element but autozone was soldout.
BTW, 05 f350, coolant filter, high idle mod, everything else stock. What's next for the Road Hog??
Old Dec 31, 2009 | 06:52 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Assuming I read this correctly, it needs to breathe. You don't need the cap on the end of the vent hose, it is ok to vent to the atmosphere. I've seen CCV's get plugged with mud on heavy equiptment and it will barely run.
Old Dec 31, 2009 | 07:05 AM
desertt5's Avatar
desertt5
I don't think he capped off the vent hose. Pretty sure he capped the other hole left in the intake.
Old Dec 31, 2009 | 07:32 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I'm sure you are right, but the way it reads is suspect. Just making sure, ya know?
Old Dec 31, 2009 | 08:39 AM
CAMPINGTOM's Avatar
CAMPINGTOM
I'm going to do some type of CCV mod soon. Still debating on whether to just vent to the atmosphere or install a filter and run back in to the intake. I've read a lot about it, but still can't decide.
Old Dec 31, 2009 | 11:56 AM
steelhead2's Avatar
steelhead2
i ran a length of 3/4 hose to the left rear spring shckle on my 04 and havent seen a drop of oil yet. if youre worried about the o-ring on the fitting that goes into the valve cover i wouldnt be.with 1' hose youll have no restriction there what so ever.the whole point of doing this mod is to get it out of the intake, dont run it back to it. go right to atmosphere with it.if youve got the end of the hose capped off un-cap it. after re-reading yours and d8's post it sounds like youve capped the 1' hose end.
Old Dec 31, 2009 | 12:37 PM
gearloose1's Avatar
gearloose1
Just as an observation.
A stealthy delete that quietly (using black hoses, etc.) at a point that is not clearly visible, with a 2 way valve (choose air filter vs. hose to rear of vehicle), is a much better choice.
You can always switch it to the air cleaner for the smog guy.... OR... even if you are caught on a surprise... you can hope they didn't look too hard.
Old Dec 31, 2009 | 12:46 PM
steelhead2's Avatar
steelhead2
they're not that bad here in wa state that they would inspect it, but maybe someday?.
Old Dec 31, 2009 | 01:48 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Mine ends after the fuel tank, mostly because I'm lazy. Too much effort to filter it and run back to intake. If they ever get that picky w/emissions here, maybe then I'd do the loop with the filter. I know the guys that inspect it, they don't even care that it doesn't have a cat. They say" diesels don't need cats, right?" I say "Dang skippy!"
Old Dec 31, 2009 | 02:09 PM
gearloose1's Avatar
gearloose1
D8...
Where I am, the inspectors think they are god.
Old Dec 31, 2009 | 02:29 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
That stinks. Where are you from anyway? Your profile only says "USA" or something like that? Just curious, since its that cold there and colder North of ya, I want to make sure my butt stays away from there, lol!
Old Jan 1, 2010 | 09:09 AM
dvldog458's Avatar
dvldog458
Can someone school me on this mod.
I've been thinking of doing this mod for some time now. I'm just concerned about evacuating the engine without any suction.(I.E. intake sucking the pressure out)
Is it really needed....or can you just leave it open to the atmoshere via an open hose or filter element and that would be enough to evac the crank case pressure?
Hope I'm making sense here.
Old Jan 1, 2010 | 09:39 AM
bismic's Avatar
bismic
The maximum pressure spec on the crankcase is 0.3 psig.
I personally wanted the suction effect of the intake.
Quite a few others do not feel it is needed.
Either way, if you run hose for a very long distance, use 1 inch hose.
Old Jan 1, 2010 | 09:47 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
You don't need a filter, you can just leave it open to vent to atmosphere. Thats what I did. I think some guys do the loop with the filter to be more environmentally friendly. I applaud that, however mine doesn't really disperse that much oil and I let it warm up in the garage for 5-10 min before I leave for work and I see nothing on the concrete floor. You are really just doing your truck a favor by not running the oil thru the intake, turbo, intercooler and piping, etc...Its not a hard job, I think it took me 1/2 hr to 1 hr, IIRC.
EDIT: Bismic, you have quicker typing fingers than me!
Old Jan 1, 2010 | 02:12 PM
dvldog458's Avatar
dvldog458
I feel the same way about the suction to evac the crankcase.
I guess as long as it has an avenue to escape it will be good to go.
