Weird Oil Leak
I was unable to repeat this weird leak and my truck still wont start.
My guess of where the oil came from, is from the front of that long horizontal cylinder that appears to apart of the Oil filter housing. I tried to take pictures the best I could.
This pic is taken from in front of the crossmember looking up the drivers side of the engine.
Any have any ideas what this is, and why only 1 cup of oil would drain out of there?
96 F250 7.3 2X4
http://photos.thedieselstop.com/showphoto.php/photo/12015/size/medium/sort/1
If the HPOP isn't full, it wont start. Most likely due to the drainage from the cooler.
The suggestion they gave you are the best you can get.
as for the Oil Cooler leaking. you can get O-rings and the gaskets from Ford pretty cheap. there not hard to fix but a PITA to get off the engine and back on. plus even if you pull the lower coolant hose you still get covered in oil/antifeeze. if you do take it off be sure to get all the gasket material off the block or it will leak. no need to put RTV anywhere when you reassemble it.
Diesel Rod
Lubrication System — 7.3L Diesel Engine
Low-Pressure System
The lubrication system is comprised of a low-pressure system and a high-pressure system. The low-pressure system provides primary engine lubrication while the high-pressure system provides the hydraulic pressure required to actuate the fuel injectors. The low-pressure system consists of the following:
Oil pump screen cover and tube (6622)
Gerotor oil pump
Oil cooler and filter assembly
The low-pressure lubricating system draws oil from the engine oil pan (6675) through the oil pump screen cover and tube, into the oil inlet passage in the front cover. The gerotor oil pump
then pumps the oil back out through the outlet passage in the front cover. The oil separates into two paths. One flow path sends oil into the high-pressure pump reservoir initial feed galley (integral to the cylinder block) and through the anti-drain back check ball. During cold start the oil feeds in two directions from the anti-drain back check ball. One feed leaves the check ball and enters the front cover. From there it enters the high-pressure oil reservoir. The second feed exits the check ball and enters the left bank valve lifter oil galley. After leaving the front cover outlet passage, the second oil path sends the oil through the oil cooler and filter assembly. Once inside the filter housing the oil filter bypass valve may open to vent excess pressure and oil back into the oil pan. After the oil has been circulated through the oil filter (6731), the oil feed then enters the main oil galley (integral to the cylinder block). Once in the main oil galley the oil is routed to the five crankshaft main bearing (6333) through five drilled and machined feed galleys (integral to the cylinder block). The five camshaft bearings receive the oil feed
through five vertical drilled and machined feed galleys connected to the main bearing feed galleys. The front main bearing feed galley also supplies oil to the right bank valve lifter oil galley through a vertically drilled and machined oil feed galley (integral to the cylinder block). The rear main bearing oil feed galley also supplies oil to the turbocharger assembly through a
vertically drilled and machined oil feed galley (integral to the cylinder block). Pressurized oil entering the turbocharger assembly is utilized to actuate the exhaust back pressure warm-up
system. The oil drains back through the turbocharger mounting pedestal and back into the oil pan. The valve lifter oil galley supplies pressurized oil to the valve tappet (6500) and to the
piston cooling oil jets. Oil from the valve tappets is routed upward to the cylinder head valve train through hollow push rods (6565). Once in the cylinder head (6049), the oil drains back to
the oil pan through return ports at each end of the cylinder head.
High-Pressure System
The high-pressure system consists of:
An injection control pressure sensor
An injection pressure regulator
A high-pressure oil pump (6600)
A left cylinder head high-pressure feed hose
A right cylinder head high-pressure feed hose
A high-pressure oil rail (integral to the cylinder heads)
An oil pressure sensor (9278)
During initial start or cold start the high-pressure oil pump receives unfiltered oil from the left side valve lifter oil galley through the anti-drain back check ball valve. Once the engine starts or during warm engine starts the check ball closes and the high-pressure oil pump receives filtered oil from the high-pressure oil pump reservoir. The high-pressure oil pump pumps the oil under extremely high pressures (4115-20577 kPa [ 600-3000 psi]) through the left and right side pressure oil rails (integral to the cylinder heads). Once in the oil rail the oil is fed to the fuel injector bores through four oil feed galleys drilled and machined in the cylinder head. The high-pressure oil then actuates the fuel injectors (9F593). High-Pressure Oil Flow 7.3L Item Part Number Description
9278 Oil Pressure Sensor
6600 High-Pressure Oil Pump
6049 Cylinder Head
9A332 High-Pressure Oil Feed Hoses
High-Pressure Oil Rail (Part of 6049)
Injector Oil Feed Galleys (Part of 6049)
9F593 Fuel Injector (8 Required)
9F838 Injection Control Pressure Sensor
Injection Pressure Regulator (Part of 6600)
6019 Engine Front Cover
6658 High-Pressure Oil Pump Reservoir
Remember after you get it running to stop it and sample the radiator and let it stand and check for oil settling out on top. If there is any oil then your cooler is shot.
Ok so as I understand it, my first steps are to check the level of the oil in the hpop through the 1/4 plug on top of the engine. Fill, or if full try to start engine. After getting running check coolant for traces of oil floating on top.
If traces of oil, replace/repair oil cooler.
So the leak that I had pour out. Was that due to the bad O rings on the cooler? I'm just wondering from where I am today, what kind of repairs the oil cooler might be needing? And what causes this type of breakage? I'm guessing that this has been building for some time and trying to start it was the breaking point.
FTE Oil Cooler Repair
I hope to get to mine soon. Maybe if I delay long enough the temp will get above 12 degrees.
