Look what I found under Valve Cover PICS
Working on a 2001 F250 7.3 CC Short bed, auto, 185K, 4x4, unknown tuner, Garrett Turbo, 4 " exhaust.
Owner advised he recently changed waterpump & thermostat and was driving along and noticed excessive white exhaust & rough running. He pulled over & engine died. He kept trying to start but no-go - he unplugged fuel bowl heater, checked fuses, changed cps, checked fuel filter, etc. and finally gave up and had it towed to a "Diesel Specialists" shop. They installed a new fuel pump and got engine to start. Advised him that there was coolant in oil and oil in coolant and that the engine needed to be replaced. He towed it to my garage and I removed the driver's side valve cover and found this:
And this in the degas bottle:
The exhaust is definately excessive white but doesn't smell like antifreeze. Engine idles rough. I dropped some oil out of pan into a bucket - no water but oil has a greenish tint to it. I also pressure checked at degas bottle and had no leak down.
Looking for suggestions/input/advice from the experts here. What do you guys think?? Cracked head, cracked block, blown head gasket, oil cooler, injector cups??? Thanks for helping.
What about the oil cooler mentioned earlier? An o-ring failure there is not unheard of and can easily mix coolant and oil. Actually, that's probably the most common cause of oil coolant mix we see.
I keep wanting to say it could be the oil cooler as well. Any way to specifically diognose it? Possibly fill radiator up till it would be above the oil cooler but not the heads and then pressure test it and see if you get oil out of the drain plug. How bad off is this motor if it is just some bad orings? How would you ever get all that moisture out of the engine?
Here's some good reading, let's hope it's not ether one of these.
https://www.ford-trucks.com/forums/1...-now-what.html
https://www.ford-trucks.com/forums/9...y-mongo75.html
I haven't pulled the engine out yet, the area behind the water pump (front cover) showed no signs of any pitting, holes, etc.
Removal of the oil cooler sounds like the next step. I will work on it tonight and post pics. Could coolant get into the oil and oil get into the coolant (both ways) from a bad oil cooler? I've been researching about the cooler, most common issue seems to be oil going into coolant (due to higher pressure).
I'm mostly concerned about the coolant getting into the oil - and the resulting damage that could or already been done - bearings, injectors, turbo, HPOP. The owner advised that he kept having to add coolant after the initial fill up of coolant after he changed waterpump. I'll find out for how long he drove it and kept adding coolant and report back.
Here's a pic of the area behind waterpump:
And here's a pic of the truck and my helper:
