Oil Pressure cut-off for fuel pumps
I'm going to have to go look for one in a junk yard if it comes down to it, I guess. I need to run down to the junk yard to get a courtesy lamp and power windows/doorlock bezels anyway...
I'm going to go look through my engine bay and see what the various oil sensors look like. IIRC, this one has a semi-circle shape and a three pin plug.
Hell, I can just put any-old oil pressure switch on in it's place, I'd just have to change the wiring! Awesome!
ok, guys, I just went through this problem myself, but with a little help from the Ford master catalog I have, I got it done. The Ford part # is E0AZ9278A. Had to have the parts man cross the # to find a replacement, as it will not apear in the listings under applications. Usually has to be ordered, but can be gotten. Good luck guys.
Great it still works. Kind of a hassle to change (at least for me). Don't know if a replacement pigtail is still available, tho. Might try wrapping a zip-tie around the threaded shank on the switch, then threading another through it and between the wires to hold it in place. (old school type fix)
on
69wannabe
40
07-31-2017 09:57 PM
zuczis
02-16-2017 11:49 AM
InfantryCPT
18
10-14-2016 12:17 PM
PapaBearYuma
09-23-2016 11:19 PM
maharashii
08-18-2003 02:06 PM
