In Colorado, 4x4 not coming on...
Took the family to Co for Christmas and now I can't get my 4x4 to engage. I have manual locking hubs and have locked them but when I switch the dash switch to 4x4, I don't hear any clicking or see the indicator light up on the dash. Where should I start?
2002 F250 Lariat 4x4 Crew Cab
Thanks!
Thanks!
Well Ford changed where stuff was located between our trucks, but mine are under the hood close to the brake fluid reservoir. Should be a two relay mount separated from the other stuff. (you may have two twin relay mounts, one for the trailer tow stuff, other for 4x4 stuff) If you see those relays there, one set will probably be the one, you shouldn't even have to take the covers off, just tap on the tops of both with a gerber or screw driver or something while the switch is being activated. Hope that works.
If it does work, get some new relays, because your probably going to have the same problem trying to DISENGAGE the 4x4!
This pic is from a wiring diagram. See bottom right corner bordered in red. Says the relays are in P113 Aux Relay Box 3. I have no idea where that box is. Maybe someone with an 02 or 03 will chime in.
Try pulling the shift motor as well. Clean it and try again. They are known to get gummed up. You should be able to activate it connected to the harness but not in the TC and see if it is working.
Where abouts are you in Colorado? If ya get stuck, depending on where you are I may be able to come out and lend a hand.
Crewcab Turbo
06-08-2011 08:19 PM
