Sponsored by: Real Truck
4x4 switch
Old May 28, 2015 | 08:58 AM
Vinford's Avatar
Vinford
4x4 switch
2005 F-350 diesel
My 4x4 switch seems to be taking a long time to lock into 4x4?
I leave my hubs in the locked position because I know the vacuum part of things doesn't work.
On my 02 when I turn the switch on the dash it goes into 4x4 almost right away.
On this truck you have to put it in a long ways before you need , plus I had to back up and fool around to get 4x4 to work once yesterday?
Can the switch on the dash go bad or is there something on transfercase that could be wrong?
Im NOT looking for help fixing the vacuum part, its the manual switching thats not working?
Old May 28, 2015 | 10:21 AM
SuperDutyScaler's Avatar
SuperDutyScaler
electrical system works in conjunction with the vacuum side of the truck, if you have vacuum leaks that will cause the delay your experiencing
iPhone from IB AutoGroup
Old May 28, 2015 | 10:26 AM
Vinford's Avatar
Vinford
Any idea why on my 02 its worked for years without the vacum lines to the front hubs?
Old May 28, 2015 | 08:07 PM
Vinford's Avatar
Vinford
So I changed that vacuum thing under the hood on the passengers side.
It goes into 4x4 now but the 4x4 light stays on.
Old May 29, 2015 | 04:51 PM
Vinford's Avatar
Vinford
I think I read somewhere about the A/C blend door being vacuum operated?
The AC doesn't blow out the vents now , but the 4x4 works decent.
Anyone know what the relation between the 2 are?
Old May 29, 2015 | 05:24 PM
Lou Braun's Avatar
Lou Braun
For an 05 truck, once you turn the selector switch to 4WD a relay energizes to send power to the actuator motor mounted on the transfer case. Once the transfer case shifts into 4WD, the vacuum relay applies vacuum to the hubs.
The relay (2 of them) are located in a box between the driver's side battery and the fender. They are identical. One sends engagement power the transfer case motor and one is used to send disengagement power.
My guess is that either a relay is on its way out or the motor on the transfer case is rusted or sticking.
Lou Braun
Old May 29, 2015 | 11:19 PM
Vinford's Avatar
Vinford
Lou Braun
What would the thing with vacuum lines and a electric plugin be that I changed?
It was on the passenger side inner fender.
Old May 30, 2015 | 02:14 PM
Lou Braun's Avatar
Lou Braun
That is a solenoid valve (I think that it is called a pulse hub solenoid). It energizes to send vacuum from the vacuum reservoir to both front hubs.
Old May 30, 2015 | 03:12 PM
senix's Avatar
senix
I think you need to check the motor at the transfer case and see if it is bad.
Old May 30, 2015 | 03:34 PM
Vinford's Avatar
Vinford
The 4x4 works now after a fashion...........................
Its the AC that doesn't blow out of the AC vents , and I remember reading somewhere the 4x4 vacuum and the blend door were related somehow?
Old May 30, 2015 | 04:29 PM
senix's Avatar
senix
a leak in the system will cause the vents to default to defrost.
Usually the leak is between the hubs and the solenoid.
Troy_455
Jul 13, 2015 08:37 AM
rutnstrut
Sep 9, 2013 04:05 PM
Crewcab Turbo
Jun 8, 2011 08:19 PM
BWPowersmoker02
Jan 2, 2010 02:33 PM
Culvert
Oct 11, 2009 10:56 AM
